Drag Racing Results - new best time
View Full Version : new best time
JLoosh
04-30-2012, 04:14 PM
Managed a 13.46 at almost 105 on friday for the best.
Previous best was a 13.57, and that was with a crazy headwind on the track, and was the first night at the track for me in the car.
Goal is under a 13.39......so I can say my 99 ls1 a4 lid catback fbody beat my cousins modded 06 m5 stang....tehehe
Not sure if ill get it but I did shave off .11 seconds my second night out, possibly with some better launches.
moge11
04-30-2012, 04:24 PM
cut THE ENTIRE base of your lower airbox out, and i GUARANTEE, you'll get it and it will probably go .20's and trap 107mph...maybe 108
projectX
04-30-2012, 04:30 PM
Seriously - try that ^^
GtoSpd
04-30-2012, 05:17 PM
x2, it works. Bumped me from 111-114 mph (went from 3.23s to 3.73s at the same time, but the gear shouldn't effect trap like that).
JLoosh
04-30-2012, 05:33 PM
I never knew it would change it that much, may have to give it a shot.
btw I will have to try to get a pic of the slips up too
JLoosh
04-30-2012, 05:38 PM
Oh and by "THE ENTIRE" base, do you mean like how they do it on installuniversity (easy reference since they have good pics), or did you do it a different way?
moge11
05-07-2012, 08:26 AM
stock you have 2 holes at the front on the lower part of air box.. cut the WHOLE backside out....make it ONE BIG RECTANGLE!!!! just flat out GUT IT!
JLoosh
05-17-2012, 08:50 PM
well I did that and the tb bypass.
Managed a 13.58 my first run...started to get wheel hop half way through first.
Second run was a 15.88....hahah...no traction at all on the starting line.
Track was being cleaned most of the time, alot of the pro cars were poping hoses and leaking stuff down the track as well as I think a few scrapped the wall, so only got two runs.
My cousin went up with his 95 camaro and ran a 12.7 for the best that night.
Here is my 15.88 run, you can see the smoke rolling off the line, never had a traction problem until that night.
The porsche didnt run bad though hah
http://youtu.be/Xz_otay1Bes
Here is my cousins run
http://youtu.be/68p6AcLT3Yo
BAMALS1
05-18-2012, 12:40 PM
Pull the spare tire and jack out too if it's still in there and along with all the free mods you should pick up a little. Run about a 1/4 tank of gas.
fraz
05-18-2012, 01:37 PM
Launch at 11 or 1200 rpms and shift it yourself 1st at 5300 and 2nd at 5800 it will give you at least a 10th.
Jarred Hodges
05-18-2012, 10:52 PM
I have seen the writeup but do you have a pic of how much you cut out. Thanks.
