Conversions & Hybrids - Low mount alternator
View Full Version : Low mount alternator
dmracing
04-30-2012, 09:43 PM
Alternator and water pump only. how did you do it?
i r teh noobz
04-30-2012, 09:54 PM
How low? I'm using an F-body alternator bracket with no idler.
dmracing
04-30-2012, 10:01 PM
Will it work with an iron block?
-TheBandit-
04-30-2012, 11:16 PM
You have to drill and tap a hole that normally isn't there on the iron block. It's no big deal though. Not sure what the belt routing looks like for that setup tough.
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap82.JPG
FastKat
04-30-2012, 11:28 PM
http://img.photobucket.com/albums/v483/mdblackz28/PS.jpg
This is how you do it using an F-body alternator bracket. (Not my car.) It will also work with a G8 alternator bracket. The F-body and G8 brackets are essentially the same with different accessory spacing. (F-body belt and accessories are farther from the engine, G8 belt and accessories are closer to the engine.)
2JZFC
05-17-2012, 09:31 PM
This is how you do it using an F-body alternator bracket. (Not my car.) It will also work with a G8 alternator bracket. The F-body and G8 brackets are essentially the same with different accessory spacing. (F-body belt and accessories are farther from the engine, G8 belt and accessories are closer to the engine.)Does anyone know what belt this setup uses? Part # or length?
TIA
FastKat
05-18-2012, 10:34 PM
FWIW, last week I saw someone use a Corvette crank pulley and a G8 alternator run an A/C belt between the two. It eliminated the need for the tensioner.
