VandykeT/A
04-30-2012, 11:26 PM
Heres my situation. Right now I've got a LTs, ORY, dumped Borla. I want to make a Borlamouth so I can run tips but the only catback I have is a Flowmaster. How hard would it be for a exhaust shop to make a Y to replace the muffler so I can run tips again? Or would I be better off finding a LM1 catback and just using the back half of it?
93camaro_zzz
05-01-2012, 12:30 AM
I think you can buy what you need at mandrelbends.com
Is it something like this? This might be the wrong size, but you get the idea....
http://www.mandrel-bends.com/catalog/collectors-x-pipes-t-s-100/parallel-2-1-merge-collectors-117/2-1-merge-collector-parallel-2-50-inlets-3-00-outlet-304ss-1511.html?osCsid=9397519b3b3e08a291834504770c72e3
99Bluz28
05-01-2012, 12:52 PM
It would be a lot easier/ less expensive to just run about a 29", 3" dia. straight pipe to the driverside tail pipe (about $17, 4ft L) and you'll also need cut off some length on the tail pipe so tip doesn't stick out further.
