Conversions & Hybrids - 67 "CUT-LS" Cutlass Convertible LY6 / 4L85e Project
kanner1
05-01-2012, 11:20 AM
This site has helped me in the past, so I thought I would throw up some pics of my 67 Oldz build. The car is..errrrr..was all original and super clean. It now has a 2009 LY6 prepped with Mast cam, springs, psi harness, hooker headers, LS3 intake, a 4L85e trans and a Ford Motorsports 3:70 posi 9inch rear. According to MAST, the motor should be in the 515-550 hp range. I built the car in my garage but it was tweaked & tuned by Larry @ Burke's Performance in Rincon, GA who has done an amazing job.
Hope you like the pics..if anyone out here is near the Savannah GA area..hit me up. We have some great shows & cruise ins going on. Thanks!!
www.icecarclub.org
garys 68
05-01-2012, 12:09 PM
Nice, like the wheels too.
What kind of gauges are those?
kanner1
05-01-2012, 12:15 PM
Thanks! The gauges are autometers. I forgot the name of the series, got them from Summitt. One is a 4 in 1, the other is a speedo they are electric to work with LS's.
-TheBandit-
05-01-2012, 01:11 PM
Very sanitary install. Turned out great.
Which cam did you put in and do you have any dyno curves?
72Cutlass
05-01-2012, 02:01 PM
Beautiful Olds, very clean. What did you useo for the fuel pump?
kanner1
05-01-2012, 02:33 PM
I can look up the cam card for you if you need it... From memory it was the SS or HO cam for VVT Gen IV's. It has not been on a dyno yet, don't know of one locally.
As for my for my fuel pump, I bought a EFI ready bolt in tank from Rock Auto with a pump already installed... Then I used the corvette filter ~ regulator combo unit off the tank.
oldgoat69
05-02-2012, 05:37 AM
Very nice, you should be proud to show this one off.
kanner1
05-02-2012, 09:37 PM
Thanks...I am enjoying this car way more than any other I've ever owned!
chaman
05-02-2012, 09:43 PM
Very nice car! Would you like to trade?? LOL!
kanner1
05-03-2012, 01:45 PM
Lol...While I do appreciate the offer, I may hold onto this one for a while :)
john 67
05-03-2012, 06:47 PM
Nice neat job.any clearence issues with the trans ? what did you use for a crossmember? any plans on changing those radiator hoses ? I just dont trust them. JOHN
kanner1
05-03-2012, 09:11 PM
John...Yeah the Trans/exhaust is very very tight. The car sits so low that the exhaust hits goingover the smallest speed bump and I can't raise the exhaust due to the Trans... So I'm carefull over the bumps! I dont want to raise the car as i love the stance. The crossmember had to be custom made by a buddy of mine, couldnt get the factory one to work no matter what I tried. I just finished the car and haven't put too many miles on it yet so not sure if the radiator hoses are here to stay or not. I'm with you, don't trust them 100% but my contact at summit swears by them, they look clean, ez to bend and I have no clue what regular hoses would work on the car if I went to the local parts store...so for now they stay!
Steve
Zimmstoy
07-09-2012, 10:41 PM
what did you use for motor mounts? did you have to do much to get it all to fit?
v8sten
07-10-2012, 12:08 AM
i miss my 67 olds cutlass
kanner1
07-10-2012, 10:56 PM
I used the hooker LS swap mounts....and their headers. Worked like a charm. Only real fight I had was a little on the Trans tunnel... But my BFH fixed that right up. Smooth sailing from there.
