Cadillac CTS-V - drag wheels w/out tire press. sensors
jj_z28
05-01-2012, 12:41 PM
so i did a search and didntt find a full answer. running stock wheels all around just bought 2 extra wheels with sticky tires w/ out tire pressure sensors.
problem is i cant disable all stability control with the tire pressure reading zero. sensors havery never really been accurate any way. so how can get get back the option of no traction devices with only the front sensors in?
Gabbiani
05-01-2012, 01:33 PM
You can either buy 2 more sensor and reprogram every time you swap wheels...
Or put two in each of your front tires to keep all four active and under pressure.
I've read that you may be able to remove all 4 and have it work but never a good confirmation on this.
BudRacing
05-01-2012, 02:33 PM
This is the simplest way to do this... unless there are simulators.
I don't even see how this is possible as they are attached to the valve stem.
Negative.
heavymetals
05-01-2012, 02:41 PM
The way to defeat them is to screw all the sensors into a vessel and pressurize it and throw it in the trunk.
Gabbiani
05-01-2012, 03:02 PM
I've seen people put tire sensors on non compatible wheels by using a giant host clamp around the center of the wheel to hold the sensor to the middle. So you could have one inside and one on the lip at the normal valve stem location. (Or 2 or 4 inside if you wanted.)
Short of it is they all have to be present and see pressure.
BudRacing
05-01-2012, 03:08 PM
This would be the route I would take. Fab up a little box, seam seal the corners, stick an air valve in it along with two sensors.... voila. Not a bad idea...
cts-v 07ct
05-01-2012, 03:16 PM
Has anyone ever tried to set all four wheels to one sensor or is it actually to smart for that?
Gabbiani
05-01-2012, 03:21 PM
Won't use the same radio ID multiple times.
Mine won't ever see a sticky tire - but I could see how annoying it would be.
CTSV_510
05-01-2012, 03:27 PM
Reprogram: http://cadillacfaq.com/faq/answers/tprepro.html
Disable: http://cadillacfaq.com/faq/answers/tpm/index.html
Disabling requires removal of all of the wheel sensors and should allow you to enter any traction/stability mode you wish.
This should actually work.
My question for you is...if you are drag racing the car, I can see that you do not want traction control enabled, but stability control should not effect anything you are doing in a straight line. Even without working tire pressure sensors, you can still kill the traction control and prevent it from pulling throttle or applying brakes.
The stability control system using steering position and yaw sensors to determine if the car is traveling in a controlled direction, but should not activate if you are simply driving straight even if you lose traction. But, if you were to lose control on the track and start going sideways, the stability control may actually help you out, and your run is probably f-ed at that point anyway.
RRsV
05-01-2012, 04:46 PM
Just use PVC pipe and stick them in it and pressurize it... no need to fab up a box etc.
BudRacing
05-01-2012, 05:41 PM
Winner
heavymetals
05-01-2012, 06:42 PM
One of these:
http://www.amazon.com/Chapin-20000-1-Gallon-Garden-Sprayer/dp/B000E28UQU/ref=sr_1_1?s=lawn-garden&ie=UTF8&qid=1335915590&sr=1-1
Drill holes and mount the TPMS and then pump it up.
itsslow98
05-01-2012, 10:13 PM
All my sensors were not functioning and I could still turn off anything I wanted.
DMM
05-01-2012, 10:29 PM
One of these:
Gotta say it...how fucked up is it that you have to stoop to having a garden sprayer onboard to "trick" your car into racing...that's just funny, lol.
Love it...just love it.
heavymetals
05-01-2012, 10:46 PM
You could also use plastic bottles as long as they seal real good.
I was thinking of something with a screw lid.
jj_z28
05-02-2012, 01:01 AM
i do more then just drag race. such as some fun freestyle type burnouts at car shows which would involve junk tires and the wheels with but sensors. can't do anything with stability control on.
im goin to try and remove all 4 sensors and just get rid of it all. anyone tried this from the cadillacfaq link that was posted?
lollygagger8
05-02-2012, 10:07 AM
You gotta look good while killing weeds!
CancerJCC
05-08-2012, 03:15 PM
This.
I have no TPMS. Dash shows ---, and I can enter all 3 "modes".
Derek98z
05-08-2012, 04:15 PM
That is a temporary fix which could work while at the track. Mine would re-register the good sensors after about 50-75 miles of driving and no longer could I turn the modes off. I would have to resync them to get the three lines
Since you are only running without two (I believe you said) eventually the computer will read the front two and disable the controls again.
tmonttt
05-08-2012, 04:35 PM
^^^ Same here. I don't have any sensors and I can still turn off traction control, go in to competition mode and turn both TC and stability off completely.
That was meant to be posted below CancerJCC
Derek98z
05-09-2012, 03:25 PM
The key is two sensors versus no sensors
