0411 pcm reflashing
0411 pcm reflashing
I am making an ignition system for my lt1, it consists of a 411 ecu, a vortec distributor, and one single coil.
This setup only requires a 4x crank reluctor, which is stock on 96 and 97 camaros (the reason i am doing this instead of the 24x coil on plug style system)
Anywyas, the only vehicle (to my knowledge at least) that used this setup is the 00-02 express van. This means i need somone who can reflash my pcm with the van programming and also tune it for my setup.
Can anybody point me in the right direction of a place where i can send my ecu to get programmed like this?
thanks in advance.
thanks in advance.
