Appearance & Detailing - One day engine bay makeover
ripgtp97
05-01-2012, 07:44 PM
So I decided it was time to clean up the bay. Took me about 8 hours total between filling holes, moving grounds, sanding, prepping, painting. The PCM wire mod was previously done before this. I think it came out pretty good for rattle can and painting outside with some wind to boot! Thoughts?
Before:
http://i50.tinypic.com/9y6d.jpg
Prep:
http://i47.tinypic.com/29kqvee.jpg
After:
http://i48.tinypic.com/5znyfm.jpg
http://i46.tinypic.com/3462vqs.jpg
http://i49.tinypic.com/28me13k.jpg
http://i47.tinypic.com/2lwb2jd.jpg
One more for good measure ;]
http://i50.tinypic.com/1pb687.jpg
kyoytey1693
05-01-2012, 08:32 PM
love the hood stripes!
dabest09
05-01-2012, 10:03 PM
That looks a lot better, did you clear it too?
I need to do this.
US_Army_Z28
05-01-2012, 10:05 PM
Looks great hope to get mine looking that way pretty soon
ripgtp97
05-01-2012, 10:19 PM
thanks! I wish i had more before pics on this computer, the towers were pretty bad beforehand. And yeah, 2 light coats of clear and one somewhat heavier. Definitely could have been better without the wind but for 30 bucks and a days work. It's a good improvement i think
LS1nterceptor
05-02-2012, 09:28 AM
What did you use to fill the holes? I'm planning on stripping down most of the engine bay soon. I was just going to sand the rough spots and spray it, but now I'm thinking I want to fill in all the holes too.
BlackScreaminMachine
05-02-2012, 10:43 AM
Signifigant improvement. Is the passanger side strut tower blochy? Or am I seeing things.
ripgtp97
05-02-2012, 10:46 AM
I think you're just seeing things maybe from the angles in the pic, its pretty uniform color all around.
As far as hole filling I used 3m bondo plastic metal. Dries pretty quick to sand, like I said i did it all in a day
pancho toco loco
05-02-2012, 05:03 PM
Looks good. Id spray those brackets that are attached to the rad support and get new nuts and bolts
ripgtp97
05-02-2012, 07:22 PM
Think i'll so some more spraying tomorrow on that stuff, good call
9WhiteCamaro9
05-02-2012, 11:47 PM
Amazing how a little time and effort can make a big change like this. Looks great OP and I'm with kyoytey1693, stripes look real good.
ripgtp97
05-03-2012, 08:27 PM
thanks white!
transam5.7lt1
05-03-2012, 09:11 PM
Looks great! By the way, hows that battery holding out for you? The Autocraft?
9WhiteCamaro9
05-03-2012, 09:27 PM
thanks white!
No problem at all. The car in a whole looks damn good itself.
originalsilverz28
05-03-2012, 09:45 PM
Looks soooooo much better. I need to do this!!
2000ssowner
05-03-2012, 11:03 PM
wow nice job man:cool:
camaroboy14
05-04-2012, 05:59 PM
Sexy sexy !!
skopers3
05-04-2012, 08:24 PM
looks great. I'd paint the STB too.
cancam99ss
05-04-2012, 08:37 PM
looks great
BOBS99SS
05-05-2012, 06:21 AM
I think it looks good,working on mine now, i plan just to do all the prep and tow it to my painter just to hit the shock towers/front suport, i think i will hold off on the fire wall untill the motor swap, did you use a high temp clear?also did you use that perfect match spray paint,think its dupicolor but its good stuff
BOBS99SS
05-05-2012, 06:23 AM
Also did you use any adhesion stuff?
ripgtp97
05-05-2012, 09:40 AM
thanks on the car compliments!
as far as the STB. it was originally red but it just seemed out of place so I sprayed it black. we'll see where that changes next hah
i sanded, threw on some adhesion promotor, and then that duplicolor perfect match you were talking about, instead of silver metallic though I think it was like ultra silver metallic, just to get a little more pop under there hopefully. It defiantely could have been sanded down a lot better and smoother to really make it shine like some of the engine bays guys have done. as far as the clear coat I used engine enamel high temp clear
MXMattGTO
05-14-2012, 04:42 PM
That's an amazing improvement.
BOBS99SS
05-15-2012, 06:04 AM
Yeah looks great, you must have been busting your butt in those 8 hours though, i have 8 hours in painting brackets and crap like that, i should start spraying the bay this week, i have decided that dupicolor works so well im just going to paint it, did you use any primer at all?
Striker
05-15-2012, 09:16 AM
Hey is it a pain to remove the entire air box assembly/tray from top of the rad support?
BOBS99SS
05-15-2012, 12:44 PM
Striker its very easy to do, its a few bolts, everything is pretty easy to take off,
LE35thSS
05-15-2012, 01:19 PM
looks really good. wish i had enough motivation to clean mine up.
GoFast908Z
05-15-2012, 01:44 PM
Looks great!
Striker
05-15-2012, 02:19 PM
I thought it was a bunch of clips that connect to the top of the rad?
BOBS99SS
05-15-2012, 04:19 PM
Once you pop off the lid there are 4 bolts, 2 on each side that hold the lid on, thats all i remeber anyway, i just took mine off a week ago, if it takes you more than 10 mins you might be a retard lol, i dont remember any clips though,
ripgtp97
06-06-2012, 11:25 AM
It's not as shiny as I would like, because I didnt bust my butt too much on the sanding ;] thanks tho guys. no primer.. i went with the adhesion promotor, and then sprayed a light coating of black for a base before the silver. I tried spraying the silver first and it wasn't really showing up well. Once the black was on there, the silver went on nice
