Fueling & Injection - i need help with dual walbros
1toofastlt1
05-02-2012, 02:50 AM
I have a 97 camaro with a stock intank pump right now with a 255 in line pump. I want to switch over to the twin in tank pumps. I got a GSS340M walbro pump sitting on the shelf right now. What other parts do I need to get this done. Thanks.
Brad Campbell
05-02-2012, 06:28 AM
http://ls1tech.com/forums/fueling-injection/856954-diy-twin-pumps-quick-cheap.html
I know it's not a 97, but this should be of some help to you.
1toofastlt1
05-03-2012, 01:20 AM
Thanks brad. Do you know if I need a Corvette sock for the end of the GSS340M pump? The M is a little different end that is machined down a little smaller
Brad Campbell
05-03-2012, 06:18 AM
It is suppose to be machined to fit a standard gm sock, but not sure what vehicle the sock comes from. I also have seen that the socks that come with the installation kits are 30 vs. the factory 70 micron(I think). Give a fuel pump vendor a call and get some advice from them. Good luck.
98Camarod
05-03-2012, 12:06 PM
IIRC, you can ask for a efi 5.0 fuel sock and it's the right one. I may be just making that up though.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
