RLS!
05-02-2012, 07:16 AM
I recently fired up an ERL 434ci bullet and noticed the pressure was lower than expected (although acceptable), according to the factory gauge. The previous engine had very high pressure, but I had replaced most all of the sensors when doing the 434 build, including the oil pressure sender.
Well, I hooked up a mechanical gauge to the oil port on the side of the block. I already had a "jumper" hose hooked up to the port to facilitate priming the engine before firing it up, so it was simple enough to toss a temporary gauge into the mix.
The factory gauge (and DIC display) showed 40psi on a cold start. At 200 deg. it dropped to 25psi and held steady at idle, rising with RPM increase. No odd noises, knocks, or rattles... it all sounded/sounds great, IMO.
The mechanical gauge? ....60psi on a cold start and 48psi at 190-200 deg.
Crazy. If it wasn't such a motherbitch to swap oil pressure senders, I would reinstall the old one and see what sort of difference there is. But, for now, I will just make a mental note of the difference and proceed with buttoning things up and working on the tune-up.
I beat myself up over this... thinking I might have pinched the pickup o-ring (even after being very careful), installed a faulty cam retainer plate or a junk oil pump, etc. It was too late, the evening I fired it, to get a mechanical gauge, so I picked one up from the local speed shop the following evening and was pleased with what I saw on the mechanical rig. fughkyeah.
random pics...
http://i27.photobucket.com/albums/c151/rlsracing/Mobile%20Uploads/Resampled952012-04-309521-28-2295246.jpg
http://i27.photobucket.com/albums/c151/rlsracing/Mobile%20Uploads/Resampled952012-04-309521-28-4095580.jpg
http://i27.photobucket.com/albums/c151/rlsracing/Mobile%20Uploads/Resampled952012-04-309520-37-5095778.jpg
http://i27.photobucket.com/albums/c151/rlsracing/Mobile%20Uploads/Resampled952012-05-019522-20-4395430.jpg
Hoping to drive it soon...
random pics...
