4U2NV-SS
05-02-2012, 11:54 AM
Need a little help,
I understand how it works and I have installed the 2 step. I ran a wire into the car.
However I want to hook it up to the clutch switch and a push button switch on my shift.
Do I use the ground from the MSD box or the 12V wire???
On the clutch switch the lower switch has a green wire and a purple with white strip, which wire do I splice into before running to my push button?
I tested both wire with a test light and either showed power. I had the key on and the clutch pushed down, do I need to try to completely start the car before it the wires show power?
Thanks in advance!!!
