FuzzyLog1c
05-02-2012, 01:35 PM
Hey, quick one: I just removed and reinstalled my clutch to fix that clutch disengagement issue that some of you may recall me complaining about.
The good news is that I fixed the problem (story for a different thread). The bad news is that I think I messed up the wiring harness or mis-wired the transmission, because I lost my speedometer and accelerometer. I'm hoping that I accidentally switched two wires, but I'm afraid that I didn't because everything else works (tach, reverse lights, transmission oil temperature).
Questions: do you recall which wiring harnesses control the speedometer and reverse lockput? The car knows when I put it in reverse (R symbol lights up on the dash), but I'm guessing that I could do it anywhere because I have to force my way through the reverse gate when stopped. I think the accelerometer sensor is up in the center console (in front of the shifter)--I can't imagine that I damaged it, but maybe I pulled its wiring harness apart when I was putting the shifter back in.
Any advice would be greatly appreciated.
