cookietime
05-02-2012, 02:24 PM
My pcm has been back and forth from tuner numerous times to try and solve my 1-2 shift rev limiter. The last advice I got was to buy software, or get someone locally to tune my pcm.
So I purchased a tunercat with data logger, 2 weeks later Im figuring things out.
I have a baby cam in my 94 camaro from 5000rmp - 5500rpm range with about 70,000 miles. (along with bigger tires, 3.73 rear)
But I kept hitting rev limiter set at 6495 , well outside my rpm range.
So tuner lower my shift points to around 5100 rmp, no change.
I learned from this site and various other sites , shift tables require RPM change AND MPH up/down shift points settings.
I could see mine mph shift points , on tunercat, were set at wot 1-2 shift,47mph,2-3 shift,87mph, and 3-4 shift at 145mph.(Watch these values)
But didnt have any references, until now.
http://www.f-body.org/gears/ is a plug-in caculator to help see RPM vs MPH.and (SHIFT POINTS)
So I plugged in my year and type car, tire size, and rear end ratio.
shift 1st 2nd3rd 4th
5000 36 67 109 155
5100 36 69 111 159
5200 37 70 113 162
5300 38 71 115 165
5400 38 73 118 168
5500 39 74 120 171
5600 40 75 122 174
5700 41 77 124 177
5800 41 78 126 180
5900 42 79 128 183
6000 43 81 131 187
6100 43 82 133 190
6200 44 83 135 193
6300 45 85 137 196
6400 46<86 139 199 <<<
Remember my redline was 6497 , and my 1-2 shift was 47 mph, that means i was winding it past 6495 rpm.
So I lowered it to the 6200rpm values, across the board , and test drove ,Bang no revlimiter, nice solid shift.
Since my powerband is in the lower RPM range, Im going to lower to the 6000 rpm range, and do some testing and tuning.
There is tons of tuning information here and on the web.
If this helps 1 person, Ive done my good deed for the day.
And I wont trash any of our tuners, Im sure they forgot more than Ill ever know.
But this worked,(is working) for me.
a little more info can be found at : http://www.lt1pcmtuning.com/tips/
http://ls1tech.com/forums/automatic-transmission/1416477-how-4l60-65e-trans-tuning-shifting-tcc-tm-w-pics.html
5000 36 67 109 155
5100 36 69 111 159
5200 37 70 113 162
5300 38 71 115 165
5400 38 73 118 168
5500 39 74 120 171
5600 40 75 122 174
5700 41 77 124 177
5800 41 78 126 180
5900 42 79 128 183
6000 43 81 131 187
6100 43 82 133 190
6200 44 83 135 193
6300 45 85 137 196
