General Maintenance & Repairs - speedo reading low
cchesser1990
05-02-2012, 06:57 PM
my speedo has been reading low for a while, about 10-15 mph. any idea how i could fix this or cost involved?
Karl101
05-03-2012, 02:54 AM
Has your rear end been changed?
wssix99
05-03-2012, 06:43 AM
Depending on the cause, the fix will be different.
In addition to the rear end, are your tires the stock size and/or have you changed the gauge face?
cchesser1990
05-03-2012, 09:18 AM
i personally havent made any changes, but the previous owner could have.
wssix99
05-04-2012, 06:55 AM
OK... Are the gauge face, tires, and rear end stock?
cchesser1990
05-04-2012, 06:59 AM
yes everything is stock as far as i know. could be some aftermarket gears in there but i have no idea.
Karl101
05-04-2012, 07:39 AM
the faster you go, the more it's off?
blade2222
05-04-2012, 07:54 AM
Also a4 or six speed?
cchesser1990
05-04-2012, 09:29 AM
hard to tell if its off the faster i go, seems like it. its a m6.
Karl101
05-04-2012, 02:31 PM
I think someone swapped gears
cchesser1990
05-05-2012, 06:35 PM
if the stock gears are 3.42, and its reading low, do you think they went higher (3.73, 3.90) or lower? (3.23,2.73)
wssix99
05-06-2012, 08:26 AM
Do you have a portable GPS? They will have a very accurate speed rating on straight roads.
If you use the GPS, you can confirm if the speed off more the faster you go. If so, you can calculate what you have. If not, you can use the GPS to fix your gauge.
cchesser1990
05-06-2012, 08:54 AM
i do have a gps so i can try that. but how would i fix it on my own? isnt it something that needs to be tuned?
wssix99
05-07-2012, 06:45 AM
If its a gear problem, yes. But you should confirm the problem with the GPS first. For a gauge face fix, its as easy as repositioning the needle on the face. (If the difference is constant at any speed.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
