Carbureted LSX forum - PCV help
RabidStreetRacer
05-03-2012, 08:30 AM
I searched and didn't really find what I am looking for.
What do I do for a cheap and effective PCV system. I have a 1994 silverado that is getting a 1999 5.3 LM7, Performer RPM intake, cam, 750cfm carb, etc etc.
What do I do with this H shape line?
http://i72.photobucket.com/albums/i169/ChrisLaBarbera/2012-05-02160015.jpg
Not sure how to upload a photo directly right now, I will search the forum for an answer.
RabidStreetRacer
05-03-2012, 08:37 AM
Here are the valve covers
http://i72.photobucket.com/albums/i169/ChrisLaBarbera/2012-05-02160023.jpg
RabidStreetRacer
And the H piece i was talking about
mike171562
05-03-2012, 09:14 AM
The H piece is the coolant line that goes under your intake.
the PCV setup should look something like this without the catch can
http://www.ls1tech.com/forums/attachments/generation-iii-external-engine/209181d1262636781-broke-my-pcv-line-what-do-catch-can-breather-factory-pcv-pcv-1ls1ext.jpg
richard david
05-03-2012, 01:49 PM
Put pcv in driverside valve cover and run it to main vacuum port on Carb then on pass side run vent tube to bottom of your air cleaner.
RabidStreetRacer
05-03-2012, 02:48 PM
PCV, should I use the stock one off of my 1994 silverado or is there another one i should get?
richard david
05-03-2012, 09:41 PM
It should work fine
Pro-Tour Heavy Chevy
06-17-2012, 12:43 AM
I tried this with the stock 2005 5.3l PCV and the car acted like it had a bad Vacuum leak because the the 5.3 style is just an open orifice. Once I changed it to the original style that came on my 71 it ran great, but would whistle real loud. Then I realized I had the vent tube on the passenger side plugged. Once I removed that and installed a breather filter the whistle stopped and the car runs great after a little carb adjustment
Z284thgen
06-17-2012, 05:31 PM
this is what i have done on mine but my pass side just has a small k&n filter on it
snook
06-17-2012, 07:04 PM
Same here, two filters on passenger side, then the pcv to the carb.
http://i30.photobucket.com/albums/c346/09181999/100_0434.jpg
Breather here, popped the cheapo one off an stuck a K&N on
http://shop.zzperformance.com/store/p/31-Valve-Cover-Breather.aspx
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
