Suspension & Brakes - Brembo's behind C5 Z06 wheels
z28_theantirice
05-03-2012, 08:41 AM
I purchased the Camaro SS Brembo's and rotors. Currently I am running a staggered setup. So I will need to purchase 18" wheels for up front, wondering if anyone else has done this, and what size spacer you needed to clear the calipers?
Sy99T/A
05-03-2012, 11:03 AM
You can run 17's up front with CTS-V calipers not sure about SS calipers, with the CTS-V's you will have to grind down the caliper's to clear inside the rim and obtain enough room with a spacer to clear the spokes of your rim, see thread F-Body CTS-V Calipers 14" Rotors and 17" Wheels
z28_theantirice
05-03-2012, 11:05 AM
You can run 17's up front but you will have to grind down the caliper's to clear inside the rim and obtain enough room with a spacer to clear the spokes of your rim, see thread F-Body CTS-V Calipers 14" Rotors and 17" Wheels
I did see that, but I'm not interested in grinding the caliper to fit within the wheel.
Sy99T/A
05-03-2012, 11:09 AM
they will not clear without grinding as far as i know. I personally have done the grinding so they would fit and you cant see where you ground the caliper with the wheel's mounted
Drokkers
05-03-2012, 12:17 PM
yep that was a good write up/ although i cant find the damn calipers for sale. Oh well. To the O/P, i thought that there was a thread on this already (do care that you started a new one) If I can find some info i will repost.
Drokkers
05-03-2012, 12:23 PM
herer ya go-page 3 is a good starting point ( http://ls1tech.com/forums/suspension-brakes/1309236-2010-camaro-ss-brembos-4th-gen-3.html ) he used a 15mm spacer i believe, just depends on your wheels! hope that helps
z28_theantirice
05-03-2012, 03:53 PM
I was hoping to hear from someone that has successfully ran the CTSV or Camaro SS Brembo behind a 18x9.5" C5 Z06 wheel. Spacer and backspacing specifically.
Drokkers
05-04-2012, 11:18 AM
did u read the post? there were a couple of guys that said it worked out great and you could always PM one of those guys as well, but if you must have someone post here with results good luck. Hope all goes well for you.
z28_theantirice
05-04-2012, 01:59 PM
I guess I missed it, unless you are referring post with the C6 Z06 wheels which isn't going to help me.
Killer_Z
05-04-2012, 02:31 PM
I have DD C5 18x9.5 front and cts v brembos ZO6 rotors and i can easily stick my thumb in between em. i used the 15mm spacer.
z28_theantirice
05-05-2012, 01:08 PM
Interesting, I wonder how those wheels compare to the Z06's?
Killer_Z
05-07-2012, 08:07 AM
not sure. but i can say i had pleanty of room to spare with the 15mm spacer. i could have probably gotten away w/ 10mm. not sure if that helps. i'm sure the 15mm spacer is all u need to be honest.
98BLOWNZ28
05-09-2012, 06:28 PM
ctsv 4 piston calipers are exactly the same as 2010 ss calipers.
just a heads up.
