HackAbuse
05-03-2012, 10:19 AM
The vehicle in question is a 2005 GTO
Okay, so I finally got my motor assembled and installed this morning. (Pulled an all-nighter, as of this post I've been awake for 36 hrs)
The motor is a 110k mile LS2 rebuild with all new bearings (rod, main, cam), a very mild cam, valve springs, and an aftermarket double-roller timing set.
I'm having the following issues and could use some experienced troubleshooting.
1. The car has a difficult time starting, sometimes I have to crank it for 10-15 seconds before it will finally start.
2. While driving, I can feel the motor 'missing', almost like a loss of power for a fraction of a second.
3. The starter is having intermittent issues turning the motor over, sometimes it can't turn the motor over at all like it's got a dead battery, but I can crank it 30 seconds later and it'll work fine.
I'm throwing codes P0340 (CMP Circuit Malfunction) & P0341 (CMP Circuit Range/Performance). Anybody have any experience with these issues?
Really need to get this vehicle back on the road ASAP!
