Generation III Internal Engine - How do you remove the knock sensor on a 2000 ls1?
703 CAMAROSS
05-03-2012, 04:33 PM
Intake is pulled off, how do I get the knock sensor's out?
BOXCHEV
05-03-2012, 04:39 PM
22mm socket I think to remove the sensor.
To remove the connector use light pressure with a pair of pliers.
703 CAMAROSS
05-03-2012, 04:43 PM
Just pull up?
BOXCHEV
05-03-2012, 05:13 PM
yeah
Grip it from the lil tabs on the side with the pliers, lil pressure on them when you squeeze the pliers and just pull up.
703 CAMAROSS
05-04-2012, 06:09 AM
I got them out thanks.
z28clark
05-04-2012, 06:12 AM
Don't be surprised if you throw a code for Knock sensors after the change out. I had to pull the intake twice - once for the sensors and again for the harness itself.
Grimes
05-04-2012, 08:17 AM
yeah, if you change the sensors/sensor connectors out, it's a good idea to put RTV silicone all around the black rubber plug so that water cannot collect inside
PowellSixO
05-04-2012, 08:42 AM
LOL. I learned this the hard way too. Helped my buddy do his knock sensors and had to do it twice because of the harness. Saved me time with my truck though. :burn:
Also + 1 on the silicone.
703 CAMAROSS
05-04-2012, 07:20 PM
Why would it throw a code if you put new ones in?
McLeod
05-04-2012, 08:59 PM
If you end up needing a harness I have one I don't need.
z28clark
05-05-2012, 05:17 AM
My best guess is from heat cycles, the plastic connectors and wiring gets brittle and not give accurate readings that the sensor is actually producing.
mdrn69velle
05-08-2012, 09:43 PM
sorry for the hijack but I need the harness I just bought a motor for my chevelle swap and it was missing it. What do the sensors do anyways??
Thanks
mdrn69velle
05-08-2012, 09:54 PM
nvm found what they are for. timing right?
crainholio
05-09-2012, 06:41 AM
The knock sensors are basically microphones that "hear" spark knock and input that data to the PCM so it can retard ignition timing.
The LS PCMs have a slick function called the Adaptive Spark Scalar that makes the change more persistent and global, knocking down the entire advance curve in percentages. It does a better job of protecting the engine vs. older systems that simply react to knock when it happens.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
