Getting fuel pump in tank w/o breaking sending unit arm
Old 05-03-2012, 06:58 PM
Z28Roxy's Avatar
Default Getting fuel pump in tank w/o breaking sending unit arm
Any tips on what to use to hold it up? Right now I have a bent coat hanger and it's not working that well.
Also I can't see crap so any other tips? I know the fuel tank has that little bucket the arm and pumps and sock have to go into and it's being a PITA.
Old 05-03-2012, 07:20 PM
RamAir95TA's Avatar
Simply twisting the pump/float assembly should be more than enough to get it in there - try twisting it to the side then pushing it down.
Old 05-03-2012, 07:37 PM
Bigtoyz's Avatar
If I remeber right when I put mine in they said to slide it in at 3 o'clock position and turn it clockwise to 6 o'clock while pushing it down.
Old 05-03-2012, 10:24 PM
Money1's Avatar
I used a extra long tiewrap and when I had it in I
just cut the tiewrap But mine had no bucket.It did have two
pumps and two strainers
Old 05-03-2012, 10:45 PM
speed_demon24's Avatar
I just pulled mine in and out without any problems. I don't see how you could damage or break it?
Old 05-04-2012, 02:20 AM
lt1slowz28's Avatar
tilt it to the side and slip it in...
the worst part is getting the spring loaded bucket assembly to go along the v shaped tank, but once you play with it a little it finds its home... bolt it down and test before closing everything up
Old 05-04-2012, 07:30 AM
quik95lt1's Avatar
youre gonna need an over head crane......a tub of wheel bearing grease and two old shoe horns....................
lol what everybody above said is right......
Old 05-04-2012, 09:53 AM
lt1slowz28's Avatar
and i thought i was hammered last night...
Quick Reply: Getting fuel pump in tank w/o breaking sending unit arm
