Parts Classifieds - TH350 swap
View Full Version : TH350 swap
jrocstar
05-03-2012, 09:40 PM
I recently purchases a th400 from jakes performance for my build. I have about 30 miles on a th350 that is decked out to hell. Only reason I am swapping it is my new setup is going to go beyond the 1000whp range this transmission was built for. transmission has:
Upgraded sprag
hardened input and output shaft
blue frictions and steels
pistons have been machined down to accomodate more clutch packs
derale transmission cooler pan
upgraded pump
really the list just keeps going on. I believe every thrust plate was replaced with bearings where applicable. I spent 1200 for first build. I blew a clutch pack in that and had to upgrade further. Blew apart the sprag on that one and had to go to a even better one. Then blew I believe the planetary gearset? I dont recall but all the parts were replaced again (including case) so it is a 100 percent new build.
It is a forward manual valve body with no trans brake.
This this is built for serious power but the power goals I have are not realistic for a th350 really so I am going to upgrade. I have over 1800 into this current transmission alone and I am throwing in a transmission cooler and the crossmember with torque arm relocation bracket on crossmember so all you will need is a convertor and shifter. I am not looking to ship this but will at buyers cost. I will post pictures later but it is currently still in the car waiting for the th400. I can have it out same day.
Any questions pm or text me 6168351464
This is a ridiculously sick transmission and a ridiculously sick price. All I ask beyond the price is you send me a video of you beating the shit out of the transmission after its in. That shit makes me happy.
jrocstar
05-04-2012, 05:14 PM
Posting pictures saturday night.
nocooler
05-05-2012, 07:25 AM
Who built it? VSS? Long tail shaft?
jrocstar
05-06-2012, 07:16 PM
it was built by a local racing shop, sharp auto supply. I will see if I can dig up the RO with the bill details. it is a short shaft. I have a custom drive shaft set up to work with a 12 bolt and 1340 yoke I will include if needed. shaft is rated for 1000whp built by precision drive shaft. I also have the spacer for the flexplate to run a th350 convertor designed for a small block chevy. vss is blocked off as I ran vehicle speed from abs system.
nocooler
05-06-2012, 07:29 PM
Thanks - not what I'm look for - good luck with sale.
