Carbureted LSX forum - You are the weakest link....
View Full Version : You are the weakest link....
GNCLONE
05-03-2012, 09:56 PM
Had some car trouble Friday night at the dragstrip. My 7.5 rear is FINE, no issues there. The motor is 100% also. It is my newly rebuilt 4L60 tranny (500 miles on it) blew the band apart. Very cool guys at the transmission shop R & R d it - all under warranty.
The trans tech didn't think the engine put out "that kind of power";)
ZONES89RS
05-04-2012, 07:21 AM
Lol, well, at least it was just sweat off your back.
speedtigger
05-04-2012, 12:58 PM
Sounds like they are good guys. Hopefully they will make this build strong enough.
boostit5.3
05-04-2012, 01:30 PM
sounds like you have found an awesome tranny shop.
GNCLONE
05-04-2012, 06:56 PM
He said they used "heavy duty/truck" parts - says I probably should've gone with "racing parts"
The funny thing is that EVERYONE thought that the 7.5 was going to be the weak link.
speedtigger
05-04-2012, 07:01 PM
My brother got away with quite a bit on his Malibu with the 7.5.
Prorac1
05-05-2012, 01:35 PM
The 7.5 is suprisingly decent behind an automatic. Its the brutal launches from a T56 with a centerforce clutch and ET Streets that will kill them, lol. Ask me how I know, lol. You can use a girdled rear end cover and make some bars to pre load the axle tubes to prevent twisting or bending the axle tubes. Eric L
My6speedZ
05-05-2012, 02:09 PM
It's cool the see them do all that though.
bad67ls
05-05-2012, 02:15 PM
the 26 spine axles will usually be the first thing to expire...
3pedals
05-05-2012, 06:26 PM
I have never liked the 700/R4, 4L60E trans.
ZONES89RS
05-05-2012, 07:24 PM
The 4l60, Ls models are better than a 700 by allot, they handle Ls motors from the factory and the 700 handle wimp motors from stock. But they still handle only so much.
bad67ls
05-05-2012, 08:53 PM
put a stick in it. problem solved. :D
3pedals
05-06-2012, 12:20 AM
HAHA,sorta,not really........., but it is fun
bad67ls
05-06-2012, 06:50 AM
Ever since i put my brian at sk speed built richmond 5 in my car,no more trans issues (nuked 7 super t-10's in 2007) (knocks on wood!) . One of the best moves i ever made. The other being the ls lol
GNCLONE
05-06-2012, 07:45 AM
So the 7.5 rear would last 5 minutes, or double that?
ZONES89RS
05-06-2012, 03:53 PM
Surprisingly, i had a 7.5 that never broke, with 383 engines beating them, dont know why it never broke, but the others....well, they did. That was with a T5, and a centerforce clutch.
The thinner the teeth, 4.10s ect, those are the ones that seem to die quickly.
bad67ls
05-06-2012, 10:25 PM
Hey one issue at a time pal. I fixed your tranny problem with my answer. You want me to build it for you too?! :D
Lol sorry i am just not a fan of automatics...ever. good luck man!
GNCLONE
05-08-2012, 08:58 AM
I had a 5 speed in a 5.0 Mustang a couple years ago. It was fun and ran high 12s, but I wanted to go with something different.
Manual pedal assemblies for G bodies are very hard to locate.
bad67ls
05-08-2012, 10:10 AM
A company just started making them...complete kit with zbar. Check the whats new section in carcraft either this months or last :D stick g body...now thats different!
ZONES89RS
05-08-2012, 08:11 PM
Got a guy here with a 408 t56 setup on a MCSS, idk what he used for pedals in the 6 speed swap but it is really nice.
ZONES89RS
05-08-2012, 08:12 PM
Think it is user name TheMerv.
Andy's Auto
05-09-2012, 09:29 AM
Funny on the 7.5s. I ran one in my 81 Malibu in 1996 with a pretty mild 454 in it. It would only ever break axles rolling out of the burnout box when the tires would bite to slow down. I put a set of Mosers in it and never had a problem after that. In 2000 I found a fairly well priced 8.5 so I swapped it in with a set of 28 spline Stranges, GM Eaton, and GM 3.73s and have a few dozen 9 second, sub 1.50 60 foot times. I have gone through three sets of brakes since then but no diff issues.
speedtigger
05-09-2012, 10:11 AM
My brother ran his 7.5 equipped early 80s Malibu with a spool, cap studs and moser axles for 2 years behind a small block 400 with nitrous. I think it went mid elevens. He claims he got into the 10s before he sold it, but I never saw it. :eyes:
ZONES89RS
05-09-2012, 01:14 PM
I am thinking i will become determined to learn how to swap mounting brackets one day so i can make whatever rear work on nearly anything, as long as length is close or identical. The ford 8.8s are ridiculously plentiful and strong as a 12 bolt, but the 1500$ 12 bolts and 9 inch rears used are not easy to pass up when they are direct bolt ins! LOL
Andy's Auto
05-10-2012, 06:53 AM
True. When I did my 78 Malibu I couldn't find a well priced 8.5 but I have 12 bolts coming out of my ears here are the shop. Grabbed a set of upper relocation brackets, built a quickie 4.10 12 bolt, bent some lines, and viola, I have 3 inches of rubber hanging outside my quarters. I bought some 16" 2000 Z28 rims and threw some drag radials and she has already hit a 1.51 60 foot. I found a set of Weld 10 holes that fit perfect so I threw a set of used 275 Mickeys on it and matched the fronts.
ZONES89RS
05-10-2012, 08:46 AM
That is great, I am wanting to learn how to get the geometry correct on getting the mounts located in that perfect position.
bad67ls
05-10-2012, 08:55 AM
I think your issue is going to be torque arm mounting. Where it attaches is cast into the centersection. Does someone make an add on bracket or something?
ZONES89RS
05-10-2012, 11:09 AM
People have made brackets that case around the center section, but I am wanting to do t with any vehicle, not just my mullet rides. Am sure I could fab something for that any day, it is still getting mounts welded on and at the proper position I am worried about.
topbrent
05-10-2012, 01:44 PM
TA mount 8.8 setup kinda like this: http://ls1tech.com/forums/gears-axles/1478765-8-8-build-unique-ta-mount-2.html
GNCLONE
11-03-2012, 07:19 PM
Well..............my 7.5 grenaded (spider gears) and my "new" 4L60 is also toast
:bang:
I'm on a really tight budget - 4 kids (oldest in college)
saving up for a THM400 & S60
speedtigger
11-03-2012, 07:44 PM
:bang:
Man, that sucks. 2 out of 2.
GNCLONE
11-03-2012, 08:14 PM
The track was really sticky - when the tree came down I hit it and the axle started to hop (which it never has before).
I think the rear siezed up for a second and took the trans out.:cry:
speedtigger
11-03-2012, 08:19 PM
Wheel hop is an absolute killer. GNs would do it when they start to make a little power. Oddly enough, mine was never prone to it and I remember my rear suspension being stock.
ZONES89RS
11-04-2012, 06:27 AM
Sorry to hear man, hope you manage to get it together pretty quick. I am waiting till income tax.
GNCLONE
11-04-2012, 12:57 PM
HA! I've got plans for my tax refund too:
http://i49.tinypic.com/m9szfa.jpg
It might be slow, but it will not break again!
ZONES89RS
11-04-2012, 02:27 PM
That's the way to do it.
3pedals
11-04-2012, 02:32 PM
The Dana60 being slower than a 12 bolt or 9" is a myth.
I run a Dana60, virtually indestructable, and a wise choice.
GNCLONE
11-04-2012, 05:35 PM
Before, I was attempting to go the lightweight route - lighter tranny, lighter rear etc. etc. and hope things would hold together because the car weighed less as a result.
Unfortunately, I must now switch to the heavy (heavy duty) route, and the car will put on some weight, but hopefully I will break things less often.
gjestico
11-04-2012, 09:46 PM
Amazing what guys will do in pursuit of that one little 60ft number.....:bomb:
