Dyno Guesses & Bench Racing Forum - 1/4 mile guess: Full bolt-on/suspension 3150lbs LS1 z28
Joe Spinners
05-03-2012, 10:45 PM
well guys, my sig has a run down of what the car has. I ran it in january at San Antonio Raceway and only made two passes. it broke the rearend on the second. it went 12.0@110mph (60ft: 1.60; 1/8: 7.4X) letting off and getting back on it a couple of times as it bounced off the 2-3 rev limiter. I missplaced the timeslip though. That was with the stock 10 bolt on 3.73s. I'm currently waiting on my MWC 9" w/ 3.89s. I recently got it weighed at a local scale here and it weighed exactly 3155lbs w/o driver. I will be taking the a/c compressor, condenser, and accumulator, lightweight carpet and removing stuff like the rear speakers and amp, etc off. I want to get the car under 3300 w/ driver. I'm at 215 lbs. Any guesses on what the car will run? I'd like to run a 11.49 by doing those changes. I know its a bit difficult because of the weather down here in Texas, but it's definitely doable from what I've seen.
02'Andy
05-04-2012, 12:06 AM
If it's the last one in your sig, you should be able to break into the 11's at that weight. But I don't think you'll be able to dial it in to 11.49. Most guys need at least a cam swap to get there, if not heads/cam. Average rule is usually .1s for every 100 lbs. Not sure if 3300 is going to be enough to touch 11.49.
c0ncEpT
05-04-2012, 08:47 AM
11.7x @ 114-115 would be my guess.
MikeG
05-04-2012, 02:08 PM
It's gonna be tough in the summertime. It looks like you have a great setup, just the summer heat is gonna make for some brutal DA's. I wish I would have had the chance to take the AC and more stuff out of my car before I sold it.
Also, how tall are you? Maybe you could drop some weight off your body and make it 3250!
Joe Spinners
05-05-2012, 06:06 PM
i appreciate the replies guys! The DA in south texas is crappy that's for sure. I know it'll be tough. I definitely need to get on a diet myself lol i'm 5'10 and am at 215, i was at 185 a couple of years ago so I need to get back into shape!
MikeG
05-06-2012, 08:42 AM
Yeah man, get in shape! I'm 5'10" and around 165-170. That's a 'free' 50 lbs off the raceweight.
Gunslinger09
05-06-2012, 10:30 AM
I say in the hot air you run a 12.2.
