Impala fuel tank
Old 05-03-2012, 10:57 PM
kirk69nova's Avatar
Default Impala fuel tank
I am interested in the Impala fuel tank to put in my 1969 Nova. I have heard these tank are pretty easily swapped with a little cutting of the trunk floor. How much exactly has to be cut in order for it to fit.
Old 05-23-2012, 08:46 PM
kirk69nova's Avatar
Know one has any input on this??
Old 05-24-2012, 12:39 AM
67maroSS's Avatar
Not sure how helpful this is, but looks like you are using EFI. I called the following company today and they quoted me an EFI tank for a 67 Camaro w/ a walbro pump for $465 +shipping.
Their new tanks are baffled and already have the hole built in for their tray. Talk to their technical support and they can tell you more.
http://www.tanksinc.com/
There is also this choice, but I've heard of fuel starvation issues at 1/4 tank.
http://www.spectrapremium.com/produc...ssemblies.html
Old 10-07-2012, 09:07 PM
crosstraining's Avatar
bump for info on the impala tank going in a Nova
Would a caprice or Buick roadmaster work as well?
Old 10-08-2012, 02:58 PM
fbrown540's Avatar
Impala, Caprice, Roadmaster and Fleetwood use the same tank. The only one different is the tank for the wagons. Wagons have gas inlet on side and 2 gallons less in size.
Old 10-08-2012, 05:37 PM
bczee's Avatar
Not ready sure that the tank will fit, the B-body tank is much larger.
Both are about 40" wide, but the B-body tank is about 6 to 8 inch longer (front to back). The fillers are both center rear, but being the tank is longer, you might have a problem with the filler neck.
As to cutting the floor of the trunk for the sender and tubes, a 9 x12 hole near the center front should do it.
BC
Quick Reply: Impala fuel tank
