Cadillac CTS-V - Spring Question
GFallen
05-04-2012, 04:11 AM
I just bought a set of eibach springs from forum member my question is how do I tell the diff in front or rear. I noticed a pair is slightly higher than the other, I'm thinking those are the fronts but not sure. thanks
FuzzyLog1c
05-04-2012, 04:16 AM
They should be the same size. What's the numbering on the coils?
furbe
05-04-2012, 04:38 AM
Wouldn't the fronts be larger at the top like the stOck ones?
CTSV_510
05-04-2012, 07:45 AM
The spring rate should be printed on each spring. the higher spring rates go on the rear
FuzzyLog1c
05-04-2012, 08:11 AM
Ah, I see what he's saying. He shouldn't have just said "higher," since these things come in different heights and spring rates. For instance, you can get an 8" tall 700 lb-ft spring, or a 10" tall 700 lb-ft spring.
GFallen
05-04-2012, 06:15 PM
one says 3878.002 the other says 3825.001. thanks
CTSV_510
05-04-2012, 07:26 PM
Hmm...mine say 1000.250.0650 in the rear...and they are 650 spring rate. Here:
http://i305.photobucket.com/albums/nn240/ctsv510/eibach.jpg
I found this one on the web, they are the 600 rate:
http://memimage.cardomain.com/ride_images/2/4932/2541/24828770034_large.jpg
furbe
05-05-2012, 02:41 AM
Is this a COILOVER spring or a stock replacement spring?
V1 or V2?
I think eibach calls them Pro Kit?
GFallen
05-05-2012, 05:55 AM
V1. stock spring replacement. My bad I should have stated that in orignal post.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
