Forced Induction - SO, im going turbo and know nothing about it, come inside
00blacka4
05-04-2012, 12:58 PM
Well after i ran 11.08 at 119 Stock Internal i decided to take it to the next level...im going turbo, so far i have a brand new GM ls2 block and a bunch of money saved heres the basic plan (PLEASE give pointers)
MOTOR
ls2 block, stock stroke forged, forged rotating assembly
317 heads ported from TSP (10:1 compression)
ls6 or ls2 intake
reversed truck manifolds
precision turbo (have NO fuckin clue how big to go)
twin in tank walbro setup
93 octain with a water/meth kit
Transmission
FULLY BUILT to the max 60E, it has literally everything they make billit input/output shafts, 5 pinion planetarys, an aftermarket input drum that holds more clutches and has a brace to keep third gear from burning out, its also sleeved...and a bunch of other shit, selling the ss4000 and probably going with a custom spec'ed converter from like FTI or yank
also have a brand new 12 bolt in the car with full suspension, and its a light ass car...
I wanna make around 700 without trying, and keep it there but i also want to be able to go up you know....700 outta run some mid/low 9s i think considering i went 11.0 with 324 to the tire
TheLS1Lover
05-04-2012, 01:06 PM
MOTOR
ls6 or ls2 intake
Transmission
The motor sounds good to me. Callies Rods and Wiseco or Diamond Pistons with the Stock Crank should suffice.
Go with the LS6 Intake Manifold, the LS2 is that pressed polymer crap and can come apart under boost.
A GT88 from Jose at FI would be nice. Or if you must go Precision the PT88. If you JUST want 700HP and no more the PT7675.
Burken01
05-04-2012, 01:11 PM
Save your money on building a th400 tranny or 4l80 for the power you want IMHO..
And when you do twin walbros, uprgrade your fuel line to -8an atleast, to support 700+
Zmg00camaross
05-04-2012, 01:16 PM
Promod 88 ;) Know going turbo huh. Well if you have any parts to sell let me know fool.
boostit5.3
05-04-2012, 01:20 PM
should have no problem reachin 700
00blacka4
05-04-2012, 01:44 PM
damnit zach found this shit already, you bastard....
And thanks fellas, the transmission is already done though, as well as the rearend and everything...
1. My buddy told me go precision 91mm has a billit wheel and ball bearing?
2. another quesiton, how much boost will i be running approx ?
3. What are those 317 heads good for power wise, whats their limit?
4. Any secrets when doing the pipeing, i have a guy doing it thats done it before didnt know if there was any little tricks of the trade i could watch for ? hes fuckin good at what he does..
5. Can i go any higher with compression or lower ? or is that about right ?
00blacka4
05-04-2012, 01:45 PM
6. Is a turbo car loud with downpipe only just crusing around ? im not worried about wot im worried about driving it around
6. and last how do i pick the best intercooler ?
1999Black_Z28
05-04-2012, 02:38 PM
Here's another option instead of starting from scratch...
http://ls1tech.com/forums/forced-induction/1541153-huronspeed-com-turbo-kit-special.html
c0ncEpT
05-04-2012, 04:30 PM
How fast do you want to go?
T4 or T6 flange?
Sell that 60 and get either a 4L80 or a TH400. Whatever it is needs a brake.
Zmg00camaross
05-04-2012, 06:57 PM
^^ True dat. Trans brake for sure. But thiink OP wants to roll race/street race.
conan
05-04-2012, 07:35 PM
I would save the money on the forged crank if your staying stock stroke and use the extra $$$ on a thicker deck head (AFR, Trick Flow, ECT ) People here have made 1,000 + HP on stock cranks.
831jd
05-05-2012, 02:55 PM
317 heads have been too 1000rwhp, get a 4l80e pt88 or a pt76 would be perfect and stock crank
