PCM Diagnostics & Tuning - low oil level light
john shea
05-04-2012, 04:26 PM
Is there a pin I can remove to turn this light off?
sreve
05-05-2012, 06:44 PM
unpluging the switch at the pan should get the light out. If that does not work jump across the plug one or the other will work.
SSickLS1SS
05-05-2012, 06:45 PM
It appears to be a normaly open switch, unpluging the switch at the pan
no it doesnt
john shea
05-05-2012, 09:14 PM
I tried both methods and neither works.
sreve
05-06-2012, 07:48 AM
Hmmmmm................
Sounds like a continuity check would be the next thing to check.
From the blue c1 pcm connector pin 70 (blue) to brown wire @ the sensor
and the black\white wire @ the conector to grd.
SladeX
05-06-2012, 08:45 AM
For mine, I just replaced the sensor. I first verified with a voltmeter that I had power and check the ground that I had continuity to the engine block.
deerslayinrednek
05-06-2012, 09:20 AM
on my LT1 I just cut the plug and connected the 2 wires together
Blasko
05-30-2012, 12:18 PM
Just take that bulb out if the cluster :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
