Forced Induction - 76mm turbo 5.3 3rd gen TA WOT runs @ 5 psi
NightmareTA
05-04-2012, 08:50 PM
Hey guys...just started street tuning with my tuner and we got it running pretty good for the time being. Running 5 psi currently but engine will be around 12-14 psi when all said and done. Thing feel like a monster already at just 5 psi though! Can't wait to start driving it and see what it's got.
Those of you who don't know, it's a 5.3 with 317 heads, ls6 cam and valvesprings, ls6 intake, and custom fabbed turbo kit with 76mm BB turbo.
http://www.youtube.com/watch?v=ssFnd9Te_Ws&feature=plcp
SPRAYED 01
05-04-2012, 09:27 PM
Awesome! what turbo?
NightmareTA
05-05-2012, 12:34 AM
Turbonetics T76 ball bearing. .96 A/R hotside and .68 F1 turbine wheel. Can't wait to up the boost! This turbo was meant for much more than 5 PSI.
5.3swap
05-05-2012, 05:34 AM
nice :) this makes me even more excited for my build. keep those vids coming
NightmareTA
05-05-2012, 09:24 AM
It's a blast man! You won't regret going this route in yours. After the 4 years of painfully building my car, those WOT runs made it all worth it. :burn:
a4ls2goat
05-05-2012, 12:35 PM
Sick! Good to see it finally running. I've been following your other threads.
You planning on changing your valve springs for high boost?
nice setup. Off boost that car drives like a pussycat.
What gears out back? It pulls for daysss
Also what redline?
NightmareTA
05-05-2012, 12:48 PM
Thanks man! As far as the valve springs, it's got LS6 springs in it. A lot of guys seem to have luck even with higher boost with the LS6 springs. I guess once I get it on the dyno, we'll see what they can take. Not too big of a deal if I do have to change them out though. Might see what it makes on 10 PSI and if I still don't hit my goal, I'll up it more. Only looking for 550-575 RWHP, so if it makes it on lower boost, I'll keep it there.
NightmareTA
05-05-2012, 12:54 PM
Also what redline?
Rear gears are 3.55's. I've been taking it to 6K RPM. Tune still needs a bit of work but for the most part, the AFR's are pretty much spot on up to redline under WOT. Part throttle is def a bit choppy at certain RPM's but the car has big 80 lbs injectors which may be contributing to the problem. Pretty sure I fucked up the tranny in that vid too. If you listen after the 2nd rip, theres a horrendous whining noise after I lift...and that was in nuetral lol. And on that 2nd rip, I start in 2nd gear since I couldn't get the tranny into 1st leaving the stop sign. Guess I got ripped yet again on our wonderful classifieds here on tech! :mad:
krzy_z
05-06-2012, 10:53 AM
man that was a sick video, now i wanna look for a 6 spd trans for my swap and do a turbo build, Your car looks like a lot of fun to drive. great work.
MillsMotorvation
05-06-2012, 09:44 PM
Very nice car, I have a cheap turbo, but other that that we have almost the same setup. What head gaskets did you use?
NightmareTA
05-06-2012, 11:11 PM
Thanks man! And so far for the 2 times I've driven it, it was a blast. It's not 100% done yet, but should be in about another month or so. Then I plan on driving the heck out of it!
It's a great setup and they put down respectable numbers most of the time. As far as head gaskets, I went with stock GM MLS gaskets.
Fireball
05-07-2012, 07:28 AM
Awesome...
man I so can't wait to get started on mine. If one T76 is that much fun....having two of them is gonna be nuts! :jest:
NightmareTA
05-07-2012, 08:15 PM
Awesome...
I hope your not putting two 76mm turbos on a 5.3! :eek2:
Haha, mine doesn't hit full spool till around 3500 RPM or so. Can't even imagine how long two would take!
02sleeperz28
05-07-2012, 08:23 PM
Nice!
TheLS1Lover
05-07-2012, 08:35 PM
427RHS actually lol.
Question. You have no fenders, where did you mount the camera? Lol, JK.
Sick car man.
NightmareTA
05-07-2012, 09:05 PM
Sick car man.
Damn, that engines gonna be a MONSTER! LOL, easy 1000 HP if set up right I would think.
As far as the gopro, it was mounted on the windshield. And I do have fenders now...my sig pic is old, haha. I've upgraded to having fenders now but still no front bumper or hood. Paint isn't cheap!
http://i13.photobucket.com/albums/a256/transamman305/DSC02369.jpg
MillsMotorvation
05-07-2012, 09:31 PM
Very nice, care to give info on wheels& Tires? Size/back spacing....ect
Nice! I am 2 or 3 months behind you.
NightmareTA
05-07-2012, 10:03 PM
No clue on back spacing...they are for a 4th gen F body though. Wheels are Ruff Racing 278 series, which I think have been discontinued. 18x8.5 front, 18x9.5 rear. Tires are nitto 555's in 245/40 front and 285/35 rear
Thanks! Good luck with yours.
Fireball
05-08-2012, 06:50 AM
Im sure it'll surpass 1K hp at fairly low boost (15psi)....this engine was built for stupid boost, I fed it 43psi in the old car :eek:
