Nitrous Oxide - Nitrous activation switch
1slowbusa
05-05-2012, 03:03 PM
What nitrous activation switch can i use. I am currently installing a fast 102 intake and throttle body with a 102 nitrous plate between the 2. What can i use for the wide open throttle switch?
5o2slow
05-06-2012, 09:36 AM
check this one out from dynatune, it activates i think 3 different ways if am not mistaken. Am using one
http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=194
Neal@NitrousOutlet
05-07-2012, 10:08 AM
You have a couple of options. You can use a Mirco Switch (http://www.nitrousoutlet.com/catalog/categories.asp?category=23§ion=92), a Window Switch (http://www.nitrousoutlet.com/catalog/categories.asp?category=26§ion=86), or Progressive (http://www.nitrousoutlet.com/catalog/categories.asp?category=26§ion=84)
All of the above will get you spraying. The links will let you see and read about the differences in the 3. Hope this helps
warriorcustoms
05-09-2012, 09:51 PM
I've got a new zex window switch with tps activation Id sell it came with my carbon fiber kit but i dont need it since im runnin 2 stages & have a nitrous outlet dual window switch
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
