LT1-LT4 Modifications - Please ID this plug on 96 Engine Harness
mguidry629
05-05-2012, 04:38 PM
I've only dealt with 93-95 LT1's and I'm putting together a 96. Can't figure out what this plugs into. It comes out of the harness by the starter wire, knock sensor, but it's longer. This is a generic pic I found online, I circled the plug I'm referring to.
Anyone?
Thanks...
Camaro350Z28
05-05-2012, 05:12 PM
rear o2 sensor?
samckitt
05-05-2012, 05:19 PM
Can you provide a larger, close up pic?
SS RRR
05-05-2012, 06:12 PM
Looks like it may be the crank position sensor plug since it looks like it's part of the cluster that goes on the drivers side.
mguidry629
05-05-2012, 08:05 PM
It's the crank position sensor....had a brain fart, should have known that. It's on the passenger side by the starter but runs up to the front. Thanks for help.
