Drag Racing Results - First track pass after year long build....how did i do ??
fastassls1maro
05-05-2012, 05:22 PM
http://www.youtube.com/watch?v=JqFB9NTmKe0&fb_source=message
Doug G
05-05-2012, 05:51 PM
couldn't see time/mph :(
shearing all 10 studs.....priceless
jsteele90
05-05-2012, 05:54 PM
Damn!!
BOLO
05-05-2012, 06:59 PM
Whoa. Why did those studs break like that? Was it overtightened? Hopefully nothing was damage under the car.
heymoej
05-05-2012, 07:13 PM
damn..........way to bounce right back.
s346k
05-05-2012, 09:07 PM
did that guy say 13.93 @ 110?
nice recovery, no doubt.
SVTconfused
05-05-2012, 09:15 PM
wheel hop is a bitch man... sorry to see that happen...
Looks like it messed up your qaurter panel... Did it?
fastassls1maro
05-05-2012, 10:34 PM
believe it or not there wasnt really any damage to the car....couple little dings in my true dual set up but thats all.
I ended up making 2 passes then after i got the new wheel studs in, however i didnt feel comfortable after all that so i pussy footed it down the track to a 13.93@110mph.
Heres some specs for anyone that cares
346ci motor 9.0:1 compression
243 heads
mahle -16cc pistons
torquer v2 112lsa cam
scat i beams
harland sharp rollers
made 400whp last weekend on the dyno
t56 trans
ls7 clutch/flywheel
moser 9" rear 4.11 gear full spool
moser 35spline axles with extended wheel studs
MWC tubular k member, upper/lower tubular arms
umi adjustable torque arm set at -2*
umi lower control arms
bmr adj. panhard bar
eibach pro kit springs
nitto 555s 315/35/17s
i think my biggest down fall was my stock rear shocks with 100k on them.
fastassls1maro
05-05-2012, 10:47 PM
oh yeah....wheels were torqued to 100ft lbs.
from what i am seeing online....it looks like this has happened to more then a few people.
time to upgrade to some ARP's and maybe even 5/8s studs
also have some SPOHN lower control arm relocation brackets that need welded on.
Doug G
05-06-2012, 05:47 AM
I've seen 5/8's break due to same reason... not a cure-all, but helps.
I went with the 1/2" option on my Moser's.
BOBS99SS
05-06-2012, 06:36 AM
Lol, dont worry man thats all part of the game, fix crap then break crap lol,anyway at least you got it on video,nice ride with 4 wheels or 2 lol
UsmcAlston
05-06-2012, 02:34 PM
That Sucks Bro but glad the car is back up
fastassls1maro
05-06-2012, 04:15 PM
car is now on jack stands again.....removing my stock 100k mile shocks. Going to be welding on my Spohn LCA relocation brackets. Still deciding on what shocks/coilovers to purchase..........
fastassls1maro
05-06-2012, 07:24 PM
heres a few pics from that day
http://i65.photobucket.com/albums/h235/02blackZ28/camaro%20rebuild/wheelhop.jpg
http://i65.photobucket.com/albums/h235/02blackZ28/camaro%20rebuild/536064_672137499622_72101635_32586566_1189065236_n .jpg
http://i65.photobucket.com/albums/h235/02blackZ28/camaro%20rebuild/538733_672137609402_72101635_32586567_2102827972_n .jpg
http://i65.photobucket.com/albums/h235/02blackZ28/camaro%20rebuild/535746_672138123372_72101635_32586580_461282055_n. jpg
these last two were leaving the line very easy.....should my car be squatting this much?
http://i65.photobucket.com/albums/h235/02blackZ28/camaro%20rebuild/582008_672395871842_72101635_32588293_1303337471_n .jpg
http://i65.photobucket.com/albums/h235/02blackZ28/camaro%20rebuild/389190_672395831922_72101635_32588292_457992721_n. jpg
s346k
05-06-2012, 07:48 PM
my auto car with a big stall squatted a LOT harder with 40k mile stock susp on it, i think you're ok.
damn, your 346cc motor made 400whp...that's nuts. makin those briggs look bad.
what cam is in the car?
fastassls1maro
05-06-2012, 08:21 PM
haha yeah meant 346ci....well technically its a 347ci lol
has a torquer v2 112lsa in it
fastassls1maro
mckchr67
05-07-2012, 10:06 AM
I was wondering how long it would take for you to post this. I'll have to put the specs in the YouTube description, since your build thread was typed by a two finger typer. I actually found a decent bit of other vids with people shear one side but none doing both sides...
k_garretson23
05-07-2012, 02:11 PM
I guess if it was going to happen anywhere that wouldve been the best place, rather than halfway down the track. nice comeback and nice car
stevo92z28
05-07-2012, 03:53 PM
Looks like the right quarter was moving a lot but it didn't damage it? That's pretty crazy. Yikes, if it hops i always get out of it. No good times or runs will come from it. Glad you got it back up and running later in the day.
fastassls1maro
05-07-2012, 06:09 PM
thanks for all the compliments.
As crazy as it looks in the video i honestly couldn't feel the car hopping. This was the first time i had ran that setup at the track. On the street the car dead hooked like crazy with little to no wheel spin. I also realized that i shouldn't have used my stock acorn lug nuts with those moser axles. I heard that they are not hubcentric axles like the stockers so they require the use of shanked lug nuts. Can anyone shine some light on this subject??
deerslayinrednek
05-07-2012, 07:03 PM
I think I found my car's twin
http://i619.photobucket.com/albums/tt273/deerslayinrednek/00z28.jpg
Do you race at Beaver often? I live in the middle of Beaver and Numidia dragway and race at both, I may head down this Friday, weather permitting. Just curious, who tuned the car?
mckchr67
05-07-2012, 07:08 PM
This is some information that I have came across on lug nuts and other people shearing studs.
http://forums.corral.net/forums/drag-racing/1194873-how-often-do-wheel-studs-break.html
http://ls1tech.com/forums/gears-axles/1369559-wheel-stud-question.html
http://www.impalassforum.com/vBulletin/showthread.php?t=269535
http://www.yellowbullet.com/forum/showthread.php?t=366299
http://www.v8buick.com/showthread.php?180559-Long-Wheel-Studs-break-street-driving/page2
ALSO have a thread going here in the regional http://ls1tech.com/forums/eastern-members/1544374-hope-isnt-anyone-here-beaver-springs-footage.html
fastassls1maro
05-07-2012, 07:21 PM
[/QUOTE]Do you race at Beaver often? I live in the middle of Beaver and Numidia dragway and race at both, I may head down this Friday, weather permitting. Just curious, who tuned the car?[/QUOTE]
Car looks nice man.......there are 2 other similar ones that i see occasionally around my town.
i go down to beaver frequently.....but this was the first time in probably 4 years that i have ran my car there.
The car was tuned by complete street performance in exton, PA.
mckchr67
05-07-2012, 08:56 PM
Do you know what brakes and rear wheels the guy was running that you got the rear end from???
fastassls1maro
05-07-2012, 09:08 PM
stock rear brakes/rotors....and there wasnt any wheels on it when it when i went down to get it. he told me it only had a dyno time on it...not any street/track miles
