General Maintenance & Repairs - Vibration :(
View Full Version : Vibration :(
Youngtransam
05-05-2012, 09:08 PM
I have noticed after an incident last summer that I have a lot of vibration when in all gear except for Park and Neutral?
Situation-
I pulled into a drive-thru going the wrong way and had to quick back out. When I put the car into reverse it kindof shifted hard into reverse. The wheels chirped and I back out. I noticed when I pulled to the next light that when stopped and in gear(Reverse,Drive, 3, 2) I had a lot of vibration but this only occurs when I am stopped. I took it to a transmission shop close by and they said that everything seemed fine with the transmission.
Any idea on what it could be?
LS1121
05-05-2012, 09:22 PM
trans mount, torque arm bushing would be the 1st thing I look at. Just go under the car with a pry bar and see what is loose or broken and then check back. oh yes check the motor mounts also.
Youngtransam
05-05-2012, 11:02 PM
Would I use the pry bar on the motor mount?:confused:
