Generation III External Engine - put headers on car wont run
View Full Version : put headers on car wont run
darrenrodgers
05-05-2012, 10:47 PM
after installing the headers and high flow cats i turn the key it doesnt seem to want to fire right away gotta hold the key for a couple second i looked over all the coil packs, spark plugs, ground wire to the motor,starter wires,02 censors,alternator,battery,fuses.when i turn the key itll turn over and fire up for a second a die,i know im getting fuel and spark the exaust gets hot.Any ideas greatly appreciated
Mumbles
05-05-2012, 11:23 PM
You seem to have covered the basics. Are you getting an SES light? If so, check the Codes. May give you a direction to look into.
Tally TransAm
05-06-2012, 08:14 AM
coolant temp sensor
Blu99T/A
05-06-2012, 09:55 AM
coolant temp sensor
It is easy to break if it is aged and the plastic housing is brittle.
thegroup
05-06-2012, 12:08 PM
Could also be the crank sensor if you knocked it off and didnt notice u did. That's been known to happen
