Map sensor help Please
I have swapped a lq4 into a 87ttype with a pt-88 turbo. I have an Innovative electronic boost controller. It has its on map sensor can I piggy back that sensor to the stock ecu? I am running an Edelbrock super vic intake and would like to not have to buy another sensor and add the clutter. The innovative map is 3bar.
1 Post
Depends on what the output of the innovative 3 Bar map is... Also, you will have to run a custom operating system in the PCM (but I would recommend doing that anyway with a boosted car)...
1 Post
Did Innovate supply any specs with the sensor? The stock one is a 0-5V signal. When you switch to a 2 or 3 Bar, you have to change the scaler in the PCM for it to read right. Which software are you going to use?
