LT1-LT4 Modifications - Installed new opti and now car won't start
95z28stock
05-06-2012, 11:08 AM
Good morning,
I'm new here. I have a 95 Z28 Camaro. It's automatic and stock. Boring I know.
Yesterday, after 14 long hours of disassembling the car and putting a new opti on and reinstalling everything, I go to start the car, and it just kept cranking and cranking. I hit the gas and the interior lights dimmed and blew fuel out of my intake and smoked.
What did I do wrong?????
I am currently taking everything back apart and tying again. I used this link:
http://www.lt1engines.com/tech/93-97-camaro-firebird-opti-remove-replace/
To do it.
If anyone has pictures or a diagram or anything that could be remotely helpful, that would be great!!!
At this point, I'm considering getting a Honda. :mad:
NVUSZ28
05-06-2012, 11:34 AM
Did you check the firing order? all connections were right, etc?
95z28stock
05-06-2012, 11:36 AM
I labeled them all when I took them off and put them on the exact same way. I really have no idea what went wrong
95z28stock
05-06-2012, 12:21 PM
So, I have "all" of my coolant drained from the radiator and from all but one of the hoses to the water pump. I put in like a gallon and a half of coolant yesterday, the car wouldnt even start, and there was none on the ground, but I only have maybe a half a gal of coolant collected. Please tell me it isn't all in my water pump about to dump all over my opti...
Zlow28
05-07-2012, 05:59 PM
When i did mine, i had my ignition wire loose, and the battery had died. Did it overheat or throw any codes?
