General Maintenance & Repairs - Car just died, what happened??????
z28pat
05-06-2012, 01:06 PM
I was driving to work, car was running fine, and I turned down the street got on the gas, car just sputtered and died, tried to crank it back on and it would fire up and die again. Only light that came on was the check gauges light (it does have gas).
car was running strong, it's got 91K miles but this was very sudden, just died.
As it was struggling to stay on and died I did hear an air/wooshing sound coming from the passenger side header area.
any ideas?
thanks
blade2222
05-07-2012, 08:31 AM
Check fuel pressure.
Ruthless909
05-07-2012, 05:21 PM
^^^ yeah that
Are you on the original fuel pump?
z28pat
05-08-2012, 11:37 AM
turns out it was throwing a maf code, so I started it with it unplugged vs plugged in and it ran fine so I'm looking into an slp or other maf
thanks
Jr.Samples
05-08-2012, 12:15 PM
thanks
Did you try plugging it back in? Maybe it had dirty connectors??
LS6427
05-08-2012, 04:28 PM
thanks
You don't need a MAF. I drove for two years with mine unplugged. Same gas mileage, same power, same everything. If anything.......it will idle a little rough at cold start for like 30 seconds.
z28pat
05-09-2012, 09:29 AM
no sh!t, I didn't know that.
didn't want to run it w/o one so I ordered a granatelli one from a member here
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
