Forced Induction - Turbo ltx guys= best head gasket
Boosted Firehawk
05-06-2012, 04:45 PM
what you guys using?
I was seriously thinking about a fel pro 1074. I will 8.5:1 cr with my setup just with the -31cc pistons and 65cc heads. Thats without head gaskets.
forgedlt4
05-06-2012, 05:47 PM
i dont know the best, so i will just share what i am using and my set-up.
I am running a really thin (.030 ish?, cant remember) COMETIC head gasket.
11.3:1 compression, 7 lbs of boost. ARP studs.
This is the third time i have re-used the same headgaskets 3 times now. never leaked or given me any issues..
robsquikz28
05-07-2012, 11:11 AM
damn thats some compression. I think the Op can use a 1074 if he wants to up the compression a bit. I have seen some people stick with standard head gaskets and others use cometics.
forgedlt4
05-08-2012, 04:00 PM
I am running E85. I am planning on doing water injection, and upping the boost to 12 lbs with the same compression.
Boosted Firehawk
05-09-2012, 06:31 PM
I think im going with 1074s this time. I will plan to use 12-15lbs
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
