Manual Transmission - clutch questions
View Full Version : clutch questions
BOOSTEDcatfish
05-06-2012, 05:18 PM
ok so im new to the corvette game, i have a 99 frc. the clutch went out and im going to replace it with a mcleod rxt. wondering if anyone on here has any info on them. also since im in there what else do i need to change. lets say the cars stock as far as drivetrain. i had a cartek in my camaro, and a friend had a RXT in his trans am and it drove like a dream. im more worried about TO bearing, slave cylinder, master cylinder, etc.
sabastian458
05-10-2012, 01:42 PM
remote bleeder, new GM slave cylinder, new pilot bearing. Also check the torque tube couplers. You will have to take the tube appart to see the rubber couplers tho.
ghost-1
05-10-2012, 04:41 PM
What he said.
sabastian458
05-10-2012, 04:46 PM
dont skip the torque tube inspection. You can cost yourself big there if you have a bad coupler. If you have the cash to spend, buy the 12mm torque tube off a newer vette. direct bolt in for a stronger part, no mods needed to do it.
Other things to consider if you have the bank, in addition to what has been said. If you want to put a transmission brace on the car, now will be the time to do it, as well as if you want to put a new transmission/rear diff mount in.
Go a head an spring for a tunnel plate too. Might as well since the stocker is paper thin and does nothing for heat blocking nor strength. I am running a 3/8th think plate and love it.
Martin@Tick
05-11-2012, 07:54 AM
Wont hurt to do everything and make it all fresh with new and upgraded clutch hydraulics.
This may be the answer to all of your questions:
http://www.tickperformance.com/tick-mcleod-complete-twin-disc-clutch-swap-package-97-04-corvette-z06/
