Cadillac CTS-V - OBX/Kooks Clamps
BudRacing
05-06-2012, 06:44 PM
I'm getting ready to install my LT OBX headers w catted connections this week and I'm going through my parts list. I want do this right the first time.
What are the ideal clamps to fit these connection pipes?
I'd prefer to order from Summit because they'll have the fastest shipping to me and I'm ordering some other parts too.
http://www.summitracing.com/search/?keyword=2.5%22%20band%20clamps&dds=1
Would any of these be better than a typical u-bolt style for this slip-fit design?
NeverSatisfied02
05-06-2012, 07:03 PM
Yes... Get the band style clamps. My car has standard clamps and they look like shit and hang down under the car. I'll be switching to those ones u posted in the link soon
USAFretired
05-06-2012, 07:12 PM
Just put OBX headers on my sons Camaro today and they came with decent clamps. If yours did not come with them I would use the Dynatech ones you have in the link. Or any other band style not the ones that compress the pipe.
shadyLS6
05-06-2012, 07:14 PM
SINGLE bolt band clamps... the 2 bolt clamps are garbage and even after you tighten them with an air tool they will leak
NeverSatisfied02
05-06-2012, 07:19 PM
I don't know which ones I have. They came on the car. I just know they hang low and I don't like them. Might be able to adjust them a little better or turn them to a better position but the way they are, they stick out and hang lower than the rest of the exhaust. It's a U bolt with the piece that slides over the opposite side and has 2 bolts (one on each side) that tightens it up. It does the job... Just ugly.
BudRacing
05-06-2012, 07:28 PM
Thanks for the suggestion. I like the taper in them that fits over both pipes.
I take it you're saying this about the straight 2 bolt band clamps. Do you think the tapered one mentioned above would fix that problem?
http://www.summitracing.com/parts/DTC-789-70250/
Otherwise it's these: http://www.summitracing.com/parts/WLK-36438/
Which aren't as nice.
NeverSatisfied02
05-06-2012, 07:31 PM
Both of those will work but the second one with the single bolt are the ones that were on my old magnaflow catback and they worked fine and didn't hang low.
BudRacing
05-06-2012, 10:03 PM
Wanting to place this order tonight.. any other comments/suggestions?
BudRacing
05-06-2012, 10:48 PM
Any thoughts on these?
http://www.amazon.com/Mr-Gasket-6312-Socket-Header/dp/B000CMF1SW
ARP is crazy thinking those simple studs are worth $120. I like these with the standard octagonal nut anyway.
Checked on summit's application verification - only lists the older chevy v8's.. :(
NeverSatisfied02
05-06-2012, 11:17 PM
I had a bad experience with header studs on a fox body I had back in the day. It came with them and that's the only car I ever had them on. Pain in the ass. I couldnt ever get more than just a couple of the studs to bottom out in the head like they all should have. Header bolts however have always worked fine for me so I really don't see the advantage to the studs.
BudRacing
05-06-2012, 11:33 PM
Just doing the install by myself... thought they may take the frustration out of it all.
shadyLS6
05-07-2012, 11:08 AM
Don't DO IT MANG! haha seriously i have those exact same band clamps on my SW 3in exhaust.. got it used missing clamps.. i thought they would be an upgrade. WRONG.. they leak slightly.. i can tell becuase there is a line of soot right at the seam where they tighting down.. learn from my mistake.. go for the single bolt band clamp OR weld the fvcker in hahah
when i do the 8.8 they are coming out and the singles are going in
NeverSatisfied02
05-07-2012, 11:28 AM
I'm voting for the singles as well. Although no band clamp will be perfect, try will tighten it better than the doubles. Once I get my exhaust the way I want it 100%, I'm
Going to weld it all solid so I'm guaranteed no leaks
vmapper
05-07-2012, 11:53 AM
I always enjoy running open header to the exhaust shop. Agree with NeverSatisfied- weld.
9t8z28
05-08-2012, 08:18 AM
X2. The 1" wide band clamps work best on stainless steel exhaust because they have a tighter clamping force. Stainless steel is stubborn because it always wants to go back to its original shape.
Wide 2 bolt (flat or stepped) band clamps only work on aluminized tubing that is softer and more flexible.
HINT: When installing the 1" wide band clamps, coat the inside of the clamp, the bolt, spacer and the pipe with WD40 or some sort of silicone lubricant. It helps the clamp slide as it is being tightened. Also, make sure that the I or H shaped center divider is centered as you tighten the clamp otherwise you will stretch the clamp and render it useless.
BudRacing
05-10-2012, 01:51 PM
Thanks for the tips guys.
