Iceman02
05-06-2012, 06:46 PM
Hi Guys,
I got a chance to take 3 passes Friday night at WIR. The track prep was minimal and was a tad cold. The DA that night was 252. I see now I had waaay too much pressure in the MT drag radials because I was at 25lbs. I tried launching three different ways:
1. Dump it fast at about 2,500 and try to limp it out right above bogging
2. Slip it fast at about 3,000
3. Slip it a little slower at 4,000
I have a line lock and did a good solid 4+second burnout and kept them spinning out of the water. That track doesnt let you drive around the water. The best 60ft I managed was a 2.13. Thats terrible. FWIW, the suspension was working I thought well (front end high, back low, no wheelhop). Nothing I did could avoid massive wheelspin.
The best the car did was a 12.9 at 114mph with that 60ft. My shift points were at 6300rpm ( a bit low for this cam). Were those 7 or so extra lbs of pressure in the tires that damaging, or wtf. I'm not used to radials just slicks, but this was frustrating. I'm going to try again in a couple weeks, if it doesnt get at least into the 1.8 range with some practice, I might as well go right to a 15" tire with some sidewall.
Any help would be appreciated:bang:
