Suspension & Brakes - What are these componenets?
Suzaku
05-06-2012, 09:47 PM
http://img.photobucket.com/albums/v516/MAIFrcrft2000/IMAG0912.jpg
http://img.photobucket.com/albums/v516/MAIFrcrft2000/IMAG0913.jpg
Was doing a k-member, shock, and a-arm swap today and I found major rust damage. What is the item sku for the components that are between the shock and the body so that I can get some replacements.
Nick D
05-06-2012, 09:49 PM
Looks like the front strut mount bushing. Mine had to be replaced when I swapped the front springs/shocks.
VinR1
05-06-2012, 10:01 PM
Those mounts really dont look that bad - you can still easily see threads. Ive seen some that one big giant glob of rust. Soak the threaded end and nut with some PB Blaster, clean the threads with a wire brush, and that nut just may come off.
The Batman
05-06-2012, 11:11 PM
I'd sand blast them and make your decision from there
SparkyJJO
05-06-2012, 11:37 PM
Hah that isn't that bad.
TruBloodTransAm
05-07-2012, 12:59 AM
Get a wire brush and some PB Blaster, should be good to go.
Suzaku
05-07-2012, 02:45 AM
Driver's side is fine, passengers is rusted all the way through. I know that one of them is the shock mount, is the other one the upper a ARM bracket?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
