160 Thermostat
Old 03-28-2004, 01:21 PM
WS6 RULES's Avatar
Question 160 Thermostat
Can I use a 160 thermostat and adjust my fan temps and be ok? Or will I stay in open loop because the pcm will think the motor has not reached operating temp. Thanks
Old 03-28-2004, 07:06 PM
ataylors's Avatar
mine works fine. It sometimes throws a code if you put it in 6th when its cold
Old 03-28-2004, 08:29 PM
samz28's Avatar
it was 75-80 today. hotlapping the t160 with 180Fan still netted 225F ECT.
on the drive home freeway it was dead on at 180F.
so its not all that great of a mod i guess.
Old 03-28-2004, 08:54 PM
Dans00Z28's Avatar
I'm by far not the expert on this stuff, but I've never heard of anybody throwing a code after putting in a 160 thermostat. I put one in, and I never reset my fans, and I haven't throw any codes (I plan on resetting them thought).
I've read that with a 160 thermostat the engine temp runs about 175, the stock stat is 180, and the engine runs about 195.
Before the needle was always half-on half-off the 210 line on the gauge, after I put in the 160 stat it was just off the gauge. I did put in an aftermarket gauge and it runs about 175 - 180.
Old 03-28-2004, 09:01 PM
ataylors's Avatar
the problem I had was I trusted the stock gauge, I now have a 160 with two holes drilled in it. So it is a little colder. If you dont alter the fan temp it doesnt run much cooler than the stock stat.
Old 03-29-2004, 09:48 AM
Moderator
jimmyblue's Avatar
You roll into open loop when ECT > 100F. So no worries on the
'stat unless it's extremely cold out and there is a lot of base
bypass (thermostat never fully closed). Which is not the case
on the Hype-Tech 160 as far as I've seen on my vehicle. With
drilled holes you might get there in arctic conditions but that's
not a problem down here in the swamp. I have one 3/32 hole
drilled in mine just for luck & bubbles.
