fergymoto
05-07-2012, 09:42 AM
Brand new FAST/Bosch part number 304208 42lb fuel injectors. They have been installed on the intake manifold pictured but have not yet been run. They go for $733 new from Summit. $400
Like new Richmond 4.56 gears for a 12 bolt. They will fit GM, Moser, Strange, etc 12 bolt rear ends. I had these in my street car for a very short time, then changed it from a 6 speed to an automatic. At that time I changed to a 4.10 rear gear. These gears were properly set up, did not wine, and have little run time on them. Included is a pinion bearing that was new when the gears were new. They are being sold in the original box. These gears are for a 4 series carrier. The Richmond part number is 6900321. $100
93-02 Trans Am side skirts removed from a 1999 model Trans Am - color is black, excellent condition as far as no cracks, tears, broken off clips. Paint is good but can't guarantee for scratches and what not. $200 for the pair
Pair of Mickey Thompson 29.5x9x15 ET Drag tires. Tubes will be included in the sale. Tires are about two years old and have been sitting most of the time, stored indoors. Lots of tread left. $100 for tires and tubes
Complete set of four wheels and tires removed from a 93-97 Camaro Z28. The wheels are in good condition, with center caps. The tires are practically brand new. They only have a couple hundred miles on them, enough to wear the little rubber stems off the tread from the tire molds. The tires are Dayton Daytona SR 235/55R16 size. Asking $450 for the complete package. I do not have lug nuts for these, but your factory Camaro lug nuts will work.
Stock 2001 LS1 injectors $75
I am also selling a lot of other parts- The following from a 1998 Z28
-RS ground effects package $300
-Doors (black) complete with glass, regulators, hinges, etc $100 each
-Rear bumper cover $100
-Rear quarters $150 each
-Hatch with glass and spoiler $100
-Catback exhaust system with Flowmaster muffler $100
-LS1 K member with lower control arms $75
-LS1 front spindles with brakes, complete with lines, wheel bearings, rotors, calipers, etc $150 for the pair
-Steering rack $125
-Fuel sending unit with pump in good working order $75
-Aluminum driveshaft $125
-Rear end complete with disc brakes $300
-Cloth door panels $50 for the pair
-Leather seats, complete set, bottoms have tears but are nice otherwise $250 for the set, front and rear
-Seat belts complete set $50
-Center console, automatic $75
-Carpet $50
I am also selling the following from a 1993 Z28:
-2.73 Posi 10 bolt rear end $100
-OEM GM left front fender $75
-OEM GM right front fender $75
-OEM GM complete front headlight bar assembly, with lights and wiring pigtails $100
-Complete K member drop out, including LT1 motor mounts, steering rack, spindles with disc brakes, wheel bearing hubs, shocks, springs, upper and lower control arms, etc $100
-AC condensor $40
-Electric cooling fans with wiring harness $75
-Left side power mirror, black $30
http://img.photobucket.com/albums/v137/ferg106/Selling/100_4755.jpg
http://img.photobucket.com/albums/v137/ferg106/Selling/100_4754.jpg
http://img.photobucket.com/albums/v137/ferg106/camarowheels.jpg
Would be interested in partial trades for MIG/TIG welders, 18' open car hauler trailer with dovetail, T56 6 speed transmission, LS1 F body headers, alternator. Otherwise cash is king.
I can ship these items or meet for local pickup in the Charlotte/Concord/Harrisburg area.
-Steering rack $125
-Carpet $50
-AC condensor $40
