VindicatedLS2gto
05-07-2012, 10:01 AM
Im puttting this add up here for a friend, truck is in good shape for being nearly 60 years old. He needs it gone asap, it'd make for a good rat rod. Truck is located in Phenix City Alabama. He can be emailed at kevinamu223@gmail.com
1953 chevy short wheel base 3100
all sheet metal removed, patched, bodywork done, undercoated and primed
frame wire wheeled clean and painted with chassis saver paint
307 GM motor with turbo 350 trans
ford 9" rearend
whole truck converted to 5 lug.
rebuilt master cylinder
rebuilt carb
new aluminum gas tank
new heavy duty aluminum radiator
new gas lines
new radiator hoses
new distrubutor
new coil
new plug wires
new carpet
new seats
new wiring harness
new back glass
new brake lines..not needed as it already has had new lines and brake work I just didn't know it at the time.
inside of cab sanded, rust treated and painted
new bullet hubcaps
gallon of hot rod flatz "steel blue" paint with hardener
ford 9" rearend
rebuilt carb
new gas lines
new radiator hoses
new distrubutor
new coil
new plug wires
new carpet
new seats
new wiring harness
new back glass
new bullet hubcaps
