Fueling & Injection - fuel system for 700rwhp with truck intake
baggins
05-07-2012, 10:05 AM
ok so im gonna use tall injectors and space the rails... i am wondering what the best budget minded fuel system would be? pumps, regulator, filters, lines? dont really know much about fuel systems so anything is appreciated. its gonna be e85 and was planning on running siemens 80s.
how would you setup the fuel lines?
thanks, Nick
Nasty N8
05-07-2012, 11:11 AM
Budget and 700rwhp on E85 do not mix. You absolutely have to do it right. You will need serious fuel volume to make that kinda power on E85.
Best solution is something like our Stage3 Street kit dual intank pumps -8 feed -6 return filter regulator and fuel rails. Give me a call I will help you get it setup correctly.
baggins
05-08-2012, 12:38 AM
by saying budget minded i meant keeping budget in mind. i have no issue paying for quality stuff i just dont want to buy something that isnt needed- also ill be running a sumped fuel tank from summit as this is going in a 65 mustang
Nasty N8
05-08-2012, 01:34 PM
In that case MagnaFuel 4301 pump filters regulator and accompanying lines fittings. I can help you get everything needed tank forward in one complete kit.
dtsti
05-08-2012, 01:41 PM
Sorry to thread jack, but can you send me a quote on everything needed minus the pumps for a 2000 TA?
ZL1Killa
05-08-2012, 08:15 PM
get em' N8!!
he sells good stuff. has everyone bought injectors to match the fuel system (pump(s) and lines?)
deatschwerks
05-11-2012, 02:40 PM
thanks, Nick
NA? N2O or FI?
NA + E85, you'll need around a 75# injector. FI, you are looking at needing at least 88#. That's assuming a 43.5 psi fuel pressure.
speedfreak90
05-12-2012, 07:35 PM
NA? N2O or FI?
i trust what DW has to say i used there injectors in another project and they have bin flawless ever since.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
