New LS1 Owners - Newbie Tech - with regards to ls3 5.3 or ls1 engine 5.7
othello911
05-07-2012, 02:59 PM
Hi all I'm new to this forum ,I hope someone can help me ! with regards to the
l33 5.3 truck engine all aluminium or the 350 ci 5.7 fitted to chevy Camaro 1997 0nwards which one is the lightest .I have a Range Rover classic county 4.2
and i am looking to fit a chevy engine .there was a company called Overfinch that used to do the conversions ,but not anymore if there is some out there that could help with details of required engine plus adaptor required for gearbox ,will be gladly appreciated thanks
conan
05-07-2012, 08:19 PM
So your question is... What is heaver the aluminum 5.3L or the aluminum 5.7L ?
If so, they would weigh very close, with in 5#'s of each other.
Also the 1997 Camaro didn't have a ls1, it still had the LT1. The corvette received the ls1 first in 97.
bww3588
05-08-2012, 02:13 AM
Yep. I think both would weigh the same. The 5.3 has more meat it the cylinders, but the ls1 has larger pistons.
I would put my money on them weighing exactly the same.
garygnu
05-08-2012, 06:28 PM
you mite get the 5.3 cheaper ,and the truck intake is a little better flowing then a ls1 intake.I would use the engine ,trans ,and transfer case and the ECM from the right truck .you can do a stand alone ls1 engine with a elderbrock ls1 intake/ignition system.
othello911
06-03-2012, 01:44 PM
thank you for your replies been away from the forum for a little while thanks again to all of you who replied .
JUSTINSWS6
06-03-2012, 01:47 PM
I have a ls1 for sale if interested
othello911
06-03-2012, 02:07 PM
Hi there,
To all you knowledgable people out there!, with regards to the above mentioned engines which one do you thing would be best suited for the range rover classic . i have gathered that the 5.3 l33 /lm7 are truck engines. which one is best suited for my application ,your responses eagerly awaited
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
