Generation III External Engine - Knock after clutch/header install
Martin HD-28
05-07-2012, 04:59 PM
I just went from a stock clutch/pp/fw to a TEX OZ-700 and SLP LT's to KOOKS LT's. ONLY when I go from a stop and pull off in first, I hear a knocking from, it seems to be, the clutch area. It sounds more like something hitting something else than just a popping/knocking though. I torqued all bolts to spec so i'm not sure what to make of it.....Ideas?
Martin HD-28
05-08-2012, 03:25 PM
Anyone???? I'm thinking maybe the exhaust bracket? Motor mount?
Possibly new clutch chatter.
sepsis
05-08-2012, 04:16 PM
After I installed my headers, they smacked the floor board on the drivers side. I had to make some room for movement with my air hammer.
1999FirehawkLS1
05-08-2012, 06:32 PM
Sounds like its time for Poly Motor mounts..ever car went put LT's on we always do the mounts cause of this reason.
Martin HD-28
05-08-2012, 07:02 PM
I went from SLP lt's to Kooks lt's strictly for the clearance, i've probaby got another 2 solid inches of clearance with the kooks. I mean they fit SOOOO good and tight underneath so Sepsis, you may be right. However, I remember telling the gus helping me with this that the Kooks y-pipe didn't fit very well to the exhaust bracket so that's another thing i've gotta check. Motor mounts would be my next mod I reckon since i've got such a large cam.... Thanks for the response guys.....
Martin HD-28
05-08-2012, 07:04 PM
MM98, there's no way this noise i'm hearing is any kind of chatter....I'm sure we torqued every bolt to specs and it's a Tex OZ-700 which isn't supposed to come with any chatter. Thanks though.
1999FirehawkLS1
05-10-2012, 04:47 PM
Tex OZ-700 clutch do have alot of chatter least the couple cars ive rode in w them compard to the monster I had when I was M6
Martin HD-28
05-10-2012, 06:44 PM
http://ls1tech.com/forums/eastern-members/903546-my-official-textralia-oz700-z-grip-review.html
The above is the average review i've read on the clutch. I had to leave town so it'll be another week or so before i can get my hands on it to figure it out but i'll keep this thread updated.....Thanks for the response...
Dr Tran
05-10-2012, 08:23 PM
I would all but put money on the Y-pipe hitting the floorboard.
Martin HD-28
05-10-2012, 09:19 PM
I thought that since the y-pipe didn't fit the exhaust bracket so good (it's offset to the right) that that would be the problem, but I put a rubber pad between the two and I still got the knock so i've gotta rule out the exhaust bracket knock (although i've considered the option that I put the bracket back on backwards). The kooks fit SO well that i'm betting it's hitting something but I haven't track it down yet.
Dr Tran
05-10-2012, 09:24 PM
My drivers side of the Y was hitting, not passenger side.
sepsis
05-10-2012, 09:36 PM
I installed poly mounts with my headers. My header collectors are 3 1/2 inches. Most are 3" that's why I think it was hitting the floor.
