LT1-LT4 Modifications - gen 1 into LT1 car. got questions
1C3 MAN
05-07-2012, 09:01 PM
Hey guys i know this might not be the right place to post this but i didnt know where els to ask.
I am about to swap a gen 1 400 sbc into my 95 camaro and need to figure out what serpentine system i can use. I know the stock one wont work because of the reverse cooling right?
anyone know what i can use?
thanks
starbucks
05-07-2012, 09:07 PM
Actually Im pretty sure u can run the stock one because the water pump is not driven by a belt with the factory serpentine setup. But you will have to run an electric water pump.
WS Sick
05-07-2012, 09:13 PM
The holes on the block will not completely line up with the bracket off the LT1 car so you'll have to modify that, and you'll have to run the neutral balance dampner because it is the pulley for the belt system off the crank. I have seen the 3rd gen f-car set-up work, i'm not sure where all he had to massage, but it all went in, he also used the LT1 rad, but I beleive the fans were hittting the waterpump pulley so he had to get slimmer fans. The injection system he was running was a holley stealthram, had to cut and weld in a peaice on the firewall to clear the distributor, and had a cowel hood. I wish I had taken pictures of it.
1C3 MAN
05-09-2012, 12:22 PM
Okay so if it can get the holes to line up with the LT1 brackets and i run an electric water pump i can use the stock stuff?
anyone els got info preferably from first hand experience?
Kevin Reed
05-11-2013, 04:02 PM
I'm curious my self on this cause I'm trying a 400 with a tuned port setup instead of stealth ram. And I'm just re drilling the accessory bracket to bolt to 400 and may use a gen 1 water pump and longer belt. How are you during this engine? Are u using factory lt1 harness/ecm?
Im not too familiar with gen I stuff, but ive seen the third gen guys modify LT1 intakes to fit their heads. I think they drill the intake for a distributor, use a remote mount tstat, and use
fittings for the crossovers. Also you can use a pcm from a vortec truck and crab style distrubutor.
This would be nice as well.
http://www.eficonnection.com/eficonnection/Order24xComponents.aspx
BOOSTED AFR
05-11-2013, 07:56 PM
Who needs factory serpentines? KRC baby!
Only kidding...
http://i1249.photobucket.com/albums/hh502/dcoler/c69f4ad8ccf84c78888032249c71fb32_zpsee8c2fce.jpg
http://i1249.photobucket.com/albums/hh502/dcoler/f7a7911a99693ad3f02bcb2897a28c74_zps267a9792.jpg
http://i1249.photobucket.com/albums/hh502/dcoler/a46058293794ef5fd25cd6dc1f100835_zps96e6db5b.jpg
TA DA! Gen I in an LT1 car...just happens to be a Corvette. With a stand up radiator too!
http://i1249.photobucket.com/albums/hh502/dcoler/3a2ebcb56d049671103e517fa39d8d50_zps04797799.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
