View Full Version : HELP: 4L60E Not Shifting Under WOT
egott_91
05-07-2012, 10:41 PM
Posting this for a guy I know.
He has a 2000 Z28 with headers and intake that he says doesn't shift under WOT, whether from a roll or dig. He said under normal driving it is perfectly fine, but if he romps on it, it will just rev until he lets out.
Any ideas?
mrvedit
05-07-2012, 11:49 PM
I know it can be hard to find things here, but this issue gets discussed in detail about every other week. Start here:
http://ls1tech.com/forums/automatic-transmission/1490803-wont-up-shift-wot.html
Typically, something has changed, such as a higher stall converter, the MPH to RPM ratio is no longer the same and the tune is now hitting redline before hitting the shift MPH. Typically a tune to reduce the WOT shift MPH by 5% or so will solve the problem.
Camarosteve44
05-08-2012, 12:14 PM
Had the same problem in my camaro. Transmission is gone
JUNK
05-08-2012, 02:22 PM
post #2 and 3 are most likely. The question is....did it just start this on its own with no work or changes to the car? If so, tranny time...if u been changing gears, tune, stall, etc. u will have to go in the tune and change WOT shift parameters as indicated.
