Generation III External Engine - 98-99 exhaust manifolds vs - 02'ish manifolds - size difference?
evo462
05-07-2012, 09:42 PM
I have a 2002 Camaro that I purchased some turbo plumbing for. The passenger side of the plumbing connects to "a factory LS1 fbody exhaust manifold". I no longer have my factory manifolds and will have to buy one for the passenger side. Before I do, I wanted to know if the overall geometry of the manifold changed over the years because if so, it might affect what I need for this plumbing. I've seen pictures of the 2 manifolds side by side, and there are slight shape differences, but I couldn't tell if the flange would be in a different spot between the two types. Would you be able to pop a 98 manifold in place of a 2002 and connect it to the same factory Y pipe with no fitment issues?
Thanks!
ibex37
06-28-2012, 01:43 PM
i could really use this info too!!! anyone care to help out. EVO462 did you get any more info on this you could post?
s346k
06-29-2012, 07:20 PM
the pass side is definitely different between 99 and 01+. not sure of 00. i replaced my manifolds with ones off an 01 car and had to have the y altered on the pass side in order for it to work. i believe the newer manifold exits farther down than the older one, but don't quote me on that.
TransamGCS
06-29-2012, 07:32 PM
i believe their is a slight difference between the two stock manifolds the 98-00 have egr provisions on the passenger side 01-02 have no egr
LS1121
06-29-2012, 08:07 PM
98-99 manifolds are the same and the 00-02 are almost the same. The 98-99 use different cats and Y-pipe than the 00-02. Either will bolt up the the motor.
The simple answer to your question is No.
Paul Bell
06-29-2012, 08:43 PM
Wasn't some years stainless tubing and other cast?
LS1121
06-29-2012, 09:30 PM
Yes 98 & 99 were tubing and the others were cast.
NVR_SPDS
06-30-2012, 11:48 AM
The 01-02 Manifolds still have the bosses for the EGR, they are just not drilled/machined to bolt up the EGR pieces to.
Paul Bell
06-30-2012, 12:24 PM
Thanks LS, I knew there was something about them.
I think advantage to 98/99 manifolds for being a bit lighter in weight and perhaps the internals being smoother.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
