Manual Transmission - Tr6060 forward shift lever interchange with T56?
roby
05-07-2012, 10:35 PM
From looking at the pictures of the Camaro TR6060 conversion to Magnum/SSR tail housing thread, I noticed the forward lever from the TR6060 is socketed. Wondering if it can be used to do a forward shift conversion on the T56?
Seems in the kits currently available to do the conversion, this lever is the custom part of the kits. If a shifter from the 03-04 Cobra or Viper can be modified to fit the forward location and used in conjunction with this lever, may make for a less costly conversion option.
Are the shift rails the same diameter between the T56 and TR6060? Anyone have a part number and cost for the lever?
Thoughts?
thesource
05-08-2012, 07:31 AM
Shift rail is the same diameter. The Camaro shift rail is two pieces but that particular piece you are referring to is usable with a little creativeness.
