Head Bolt Sealant?
Old 05-07-2012, 11:57 PM
93LS1S10's Avatar
Default Head Bolt Sealant?
Im doing my1st LS head and cam swap. Im using arp head bolts. Do i need to put anything on the threads other than the torque lube?
Thanks
Old 05-08-2012, 12:07 AM
bww3588's Avatar
Just the moly lube that comes with them. All head bolt holes are blind. Just make sure the holes are 100% clean before installing them or you will blow the bottom out of the hole.
Quick Reply: Head Bolt Sealant?
